I have a pc that got a new cpu and motherboard, and i have the same drives. When i go to launch the games manually, or open the epic games library, it doesn't see the games, even thought i can see the files. When i try to launch a game through the files (fortnite) the anti-cheat comes up, then doesn't go past it. Do I really need to reinstall my epic library?image.thumb.png.009c13866523be44b252e1935d15e2e2.png
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1223787-epic-library-not-showing-up/
1 minute ago, Cvet76 said:
I don't know if there's an option to verify the library files in the Epic games store, but if there is, I'd do that..I know that's an option in Steam
i cant find one, and i do have 100 megabit internet, but fortnite alone could take an hour. I have over 150gb of games id have to reinstal. 😢
Bios database
prior build:
Just now, Cvet76 said:
thats for verifying a games files post install. here
Bios database
prior build:
I just bit the bullet and started the reinstall
Bios database
prior build:
h, well..at 100Mbit it won't be that much of a bother, I guess. I have a bunch of games installed and CoD MW/Warzone take up 194 gigs alone :P
These game sizes are getting ridiculous.
I was off by a  hundred gb. I had almost 250 gb. I wanna put a hole in a wall.
Bios database
prior build:
