CoolerMaster NR400 wo/odd
Ryzen R3600
CoolerMaster Hyper 212 rgb black edition
Gigabyte B550M Aorus Elite
G.skill Trident Z Neo RGB 3600mhz cl16 16gb x 8gb
Samsung 970 Evo Plus 500gb m.2 nvme (Boot Drive)
Lexar ns100 1tb 2.5 inch ssd
Toshiba 7200rpm 4tb hdd
PowerColor Red Devil RX5700xt 8gb gddr6
CoolerMaster MWE 650W 650w 80+ gold full modular
CoolerMaster MasterFan SF240P A-rgb (front case fans)
CoolerMaster MasterFan MF140R A-rgb (exhaust)
Coast : $2108 (sgd)
Peripherals
G29 Driver wheel (from dad's older machine)
Driving force shifter
G413 Keyboard
G603 mouse
Cost $388
This was my first high end build for a friend's simulator build, I hope I didn't do too bad
Silent Cerberus - Fractal Design Core500,Ryzen R7 3700x,Scythe Fuma 2,Gigabyte Aorus B550i Pro AX,Crucial Ballistix Elite 3200mhz cl16 16gb,Adata XPG SX8200 nvme 512gb m.2 ssd,Lexar NS100 1tb ssd,Red Dragon RX5700 8gb(bio flashed 5700xt),Corsair SF600 SFX 600w 80+ platinum F-Modular.
Hades - dO.Ob Look into my eyes and see the dark eternal abyss that is your soul and pay for your hidden sins.
Cerberus - the hell hound that guards the gates of hell. Once you enter you'll never escape.
https://linustechtips.com/topic/1223314-drivingflight-simulation-system/
pretty bad mobo
16 gb or 8gb?
too expensive for a gaming build
overall pretty good, i'd change the motherboard though
Definitely get a better motherboard.
Other than that it sounds good, though unless you've got a really good deal on the 5700XT Red Devil, I'd probably get a 2070S or cheaper 5700XT instead (Red Dragon, Pulse, Gaming X).
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
3 minutes ago, boggy77 said:
pretty bad mobo
16 gb or 8gb?
2 x 8gb per set
The red dragon was sold out the owner gave us the devil at dragon's price.
7 minutes ago, boggy77 said:
pretty bad mobo
I think you're confusing the B550 with the B450. The B550 Aorus Elite uses the same VRM as the B550 Aorus Pro, which performs fine.
You're confusing the B550M Aorus Elite for the B550 Aorus Elite.
B550 not 450
6 minutes ago, boggy77 said:
Yeah the b550m aorus elite is bad, the b550 aorus elite is good
Confused?
Guess we'll have to get the pro one then
*gigabyte b550 aorus pro ac.
10 minutes ago, boggy77 said:
Go 2x16
He wanted to fill the slots, look at the pretty lights *hypnotizes you*
12 minutes ago, StrawberryShortCakes said:
Confused?
Gigabyte's mATX Elite and Pro are not the same as the ATX versions.
The ATX B550 Aorus Elite is a good board. The B550-A Pro from MSI has a little more features I think, but the Elite has a better VRM (though the A Pro can still handle a stock 12-core or even 16-core).
The ATX B550 Aorus Pro is pretty much as good as B550 gets (along with the Strix B550-F, B550 Gaming Edge WIFI and B550 Tomahawk) until you start getting into overspending territory for a B550 motherboard. It will run an overclocked 16-core 3950X no problem, and it's also got better rear IO than the MSI boards (unless you don't need more than 5 USB-A ports).
1 hour ago, boggy77 said:
Yeah but he might lose some ram speed, as ryzen struggle to run 4 sticks at the rated speeds.
That I didn't know have to let him know then.
