Hello,
I bought some used parts and I got everything assembled and I push the power button, the fans will spin and the power LED comes on, but I don't get anything on the monitor. No splash screen saying press delete to enter BIOS. I reset the CMOS with the jumper and the battery and neither worked. Anything else I should try?
Athlon X4 760K | MSI A88X-G43 | 8GB G.Skill Ripjaws 1333Mhz | MSI R7 260X 2GB | Corsair 300R | Corsair CX430 | 640GB HDD | Windows 7 64-bit
HP W2071d 20" 900p TN | Stock Dell K/B | Microsoft Comfort Optical Mouse 3000 + SteelSeries Qck Portal 2 Ed. | Grado SR80i + cheap 2.0 speakers
https://linustechtips.com/topic/122315-posting-help/
Do you have a GPU installed?
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/122315-posting-help/#findComment-1627449
Your monitor is hooked up to your graphics card, right?
https://linustechtips.com/topic/122315-posting-help/#findComment-1627450
The onboard graphics.
Edit: One of the mods can move this to the troubleshooting section. I forgot it was there.
https://linustechtips.com/topic/122315-posting-help/#findComment-1627502
Please quote then we know what reply you're awnsering to.
But do you have a graphics card installed? if yes hook it up to that one
https://linustechtips.com/topic/122315-posting-help/#findComment-1627535
No I do not have a GPU installed. I have the VGA cable hooked up to the motherboard. I have checked the monitor and the cable, they are both working fine.
https://linustechtips.com/topic/122315-posting-help/#findComment-1627543
Anyone have ideas?
https://linustechtips.com/topic/122315-posting-help/#findComment-1628759
Anyone have ideas?
Is it rebooting over and over again? Or just staying on.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/122315-posting-help/#findComment-1628857
It is just staying on. There is no boot loop.
https://linustechtips.com/topic/122315-posting-help/#findComment-1628905
Welp, other then alternating the ram, trying one stick at a time and making sure all the cables are plugged in and making sure it is not shorting on the case and the mb is mounted right? Not much you can do. You can try another PSU if you have one.
You just need to eliminate one thing at a time and it helps if you have other hardware. Prob a dead motherboard if everything is plugged in right and alternating ram doesn't work.
https://linustechtips.com/topic/122315-posting-help/#findComment-1629051
Will try that tomorrow, its midnight and I don't want to do anything stupid.
https://linustechtips.com/topic/122315-posting-help/#findComment-1629099
