I recently bought a new pc but i got a problem.
My graphics card: asus strix RTX 2060 OC 6GB
I installed all the drivers
But when i restart my pc it gives the message: load vender.dll fail. Install VGA driver please.
I read on another topic that it had something to do with nvidea drivers not installed. So i went on asus' page and downloaded the VGA drivers for this graphics card.
I downloaded and installed it. I opened the program and it was checking for system compatibility.
That's where the problem is. It says: NVIDIA installer cannot continue, this nvidia graphics driver is not compatible with this version of windows. But i certainly know i downloaded the version for windows 10 64-bit.
I hope anyone can help me.
https://linustechtips.com/topic/1221892-urgent-help-needed/
don't use asus website for gpu drivers, use nvidia's website.
https://www.nvidia.com/en-us/geforce/drivers/
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1221892-urgent-help-needed/#findComment-13820103
Use ddu. Then install the drivers from nvidea.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1221892-urgent-help-needed/#findComment-13820120
