Hi All,
So I'm currently building a PC with the following specifications
I9-9900K
360MM MSI MAG AIO
Gigabyte Z390 Aorus Pro
Gigabyte Aorus 2080TI
Deepcool 750W Gold 80+ Full Modular PSU
So I tested the PC without the GPU in the case, boots no problems, I connected all the cables like fans, power switch , USB etc then put in the GPU, plugged it all in and BOOOM,  not even the motherboard is showing power when I plug in the power cord, click the switch and go to turn it on. After removing the GPU the PC still refuses to turn on and shows no sign of life and I'm now stressy spaghetti because this is kinda of an expensive issue
If anyone could help that's appreciated
https://linustechtips.com/topic/1221096-pc-build-help-urgent/
Clear the cmos.
Re seat everything. Try with one stick at a time. After that plug the GPU and try booting with the I-gpu. If it does check if the card is detected.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1221096-pc-build-help-urgent/#findComment-13813172
3 minutes ago, TofuHaroto said:
Clear the cmos.
Hi there,
CMOS can't be cleared as the motherboard isn't showing any power as when you give it power it flashes meaning I can't even clear CMOS, just tried with one stick or Ram, no GPU after reseating everything, PSU is still working.
https://linustechtips.com/topic/1221096-pc-build-help-urgent/#findComment-13813185
3 minutes ago, Legend223 said:
Take it out of the case and then try.
Inspect the socket for any bent pins.
Build Log:
https://linustechtips.com/topic/1221096-pc-build-help-urgent/#findComment-13813190
Upon unplugging the cables I unplugged the RGB fans, the system as the time wasn't connected to any power for a good minute, motherboard flashed (all the RGB lights) upon turning it on without the RGB fans in everything worked fine!
Thank you for all the help
https://linustechtips.com/topic/1221096-pc-build-help-urgent/#findComment-13813197
Rma the rgb strips or just don't get any it will look better that way :P ( no jk do what ever you want lol ).
Build Log:
https://linustechtips.com/topic/1221096-pc-build-help-urgent/#findComment-13813198
Thanks for your help guys, appreciated that you guys help make a forum that you can come to and get replies
https://linustechtips.com/topic/1221096-pc-build-help-urgent/#findComment-13813207
