Technically there is always a bottleneck.
But in this context. No.
But if you can wait. Then wait for Ampere and big Navi as they're right around the corner.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1220658-need-help/#findComment-13809645
1 minute ago, angelyo123 said:
and I got a 2070 super for my B-Day
Ah alright then.
As I said everything Bottlenecks but in this context it won't.
Build Log:
https://linustechtips.com/topic/1220658-need-help/#findComment-13809651
I mean may lose a couple of frames but most likely still push more than what you get now
CPU - I9 10900 | CPU Cooler - Corsair Hydro Series H100x AIO | Motherboard -  Aorus B460 PRO AC | RAM -G.SKILL Ripjaw V series 4x8GB 2666MHZ | Graphics Card - Gigabyte RTX 3070  | Power Supply - Cooler Master 650w  | Storage -  Working on a new Spicy
Operating System - Windows 10 Pro
https://linustechtips.com/topic/1220658-need-help/#findComment-13809653
