Hi all,
I am currently thinking about building my first custom loop. I spend a few hours yesterday, trying to oc my r7 1700 to its limit and I am currently at 4.05GHz at 1.425V. The problem is, that the CPU hits 90°C under prime95 and it is to high, as far as I know. I am currently using a beQuiet! shadow Rock 2. It was really good under my mild oc before, but it is just not enough at 4.05GHz. How much of an improvement could a custom loop give me?
Can you guys recommend any parts for that?
Greetings Devryd
https://linustechtips.com/topic/1220243-first-custom-loop/
12 minutes ago, Devryd said:
Hi all,
Greetings Devryd
Most probably none. 1st Gen ryzen had a hard cap at around that 4.0~4.1 GHz mark. While it may improve temperatures to the mid-high 80's (guess) you have no more overclocking headroom just by silicon quality.
https://linustechtips.com/topic/1220243-first-custom-loop/#findComment-13806033
Just now, Devryd said:
I should have said that more clearly, sorry.
I ment the temperature improvement.
At those high voltages, I think the efficiency is so low that the temps will be quite bad even with a good custom loop. Optimistically, high 70's. More likely to be in the mid-high 80's. Of course it all depends on ambient temperature, radiator surface area, and airflow.
https://linustechtips.com/topic/1220243-first-custom-loop/#findComment-13806044
1 minute ago, Devryd said:
Thats, too bad...
I thought at these high loads a custom loop would really shine.
Then I guess, I don't have much choice than to lower my OC a little
With a 7nm CPU the heat is focused in a very small surface area. You can end up in a similar situation as Jayz2cents when he ran 4x480mm rads with an 8700K that wasn't delidded - the liquid temperature was basically ambient but the CPU still reached 80°C.
PC: CPU: Intel i7-4790 MB: Gigabyte B85N RAM: Adata 4GB + Kingston 8GB SSD: Samsung 850 EVO 500GB GPU: XFX GTR RX 480 8GB Case: Advantech IPC-510 PSU: Corsair RM1000i KB: Idobao x YMDK ID75 with Outemu Silent Grey Mouse: Logitech G305 Mousepad: LTT Deskpad Headphones: AKG K240 Sextett
Phone: Sony Xperia 5 II
https://linustechtips.com/topic/1220243-first-custom-loop/#findComment-13806056
What’s the use for the chip and why is that temp a concern?
https://linustechtips.com/topic/1220243-first-custom-loop/#findComment-13808300
@Mick Naughty I use it for gaming mainly and also for university. I am just not really comfortable with running it at 90°C under full load. I know, it is technically ok, but it is just really high. If it gets even a few degrees warmer in my room, it will start to throttle. And also, I am only getting these temps with the side panel off. If I put it on again, it would be a lot warmer, because my case (be quiet! pure base 600) has pretty bad airflow.
https://linustechtips.com/topic/1220243-first-custom-loop/#findComment-13809743
But you said it does it on prime. What are the real world temps if you’re just gonna game?
https://linustechtips.com/topic/1220243-first-custom-loop/#findComment-13810084
With how old the 1700x is, I wouldn't throw money at it for a little bit of cooling.
Gaming - AMD TR 3970X | ASUS ROG Zenith Extreme II | G.SKILL Neo 3600 64GB | Zotac Nvidia 2080 Ti AMP | 2x Sabarent 1TB NVMe | Samsung 860 EVO 1TB SSD | Phanteks Enthoo 719 | Seasonic Prime Ultra Platinum 1000w | Corsair K70 RGB Lux | Corsiar M65 | 2x ASUS Rog PG279Q | BenQ EW3270U | Windows 10 Pro | EKWB Custom loop
ITX - Intel i7-10700k | Asus ROG Z490-I Gaming | G.SKILL TridentZ RGB 3200 32GB | EVGA 2080 Super| Samsung 970 Evo 1TB | Samsung 860 Evo 1TB SSD | NZXT H1| Windows 10 Pro
HTPC - Intel i9-9900k | Asus ROG Maximus XI Code | G.SKILL TridentZ RGB 3200 32GB | EVGA 1070 | Samsung 970 1TB | WD Blue 1TB SSD | NZXT H700  | EVGA G3 1000W | Corsair H150i | Windows 10 Pro
Servers - SuperMicro 846 | 2x 2695L V2 | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 24 x 6TB | FreeNas - SuperMicro 826 | 2 x 2695L | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 8 x 10TB | 847 24 x 1TB SSD | Windows Server 2019
Work - Dell XPS 15 9560 | i7-7700HQ | 32 GB RAM | 1TB NVMe | 4k dsiplay
https://linustechtips.com/topic/1220243-first-custom-loop/#findComment-13811839
