So I recently bought an acer predator Orion 3000 with an i7 9700 cpu, obviously this is a prebuilt if you couldn’t pick it up, but point being it is at a 3.0 ghz frequency and I was wondering if there was anyway to increase that aswell as to the max I could increase it to if possible, if anybody has an answer for me or questions that would be muchos appreciated.
thanks
https://linustechtips.com/topic/1219859-i-need-help-asap/
That's just the base clock. The CPU will boost to 4.7 GHz under load. It's technology Intel implemented about a decade ago so that the CPU won't run at its max speed all the time, chugging power and reducing its lifespan. Whenever you're doing something demanding, it should boost to 4.7 GHz provided the temperatures are safe (below 90C)
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1219859-i-need-help-asap/#findComment-13802706
14 hours ago, Darilliz said:
i7 9700
To my understanding non K CPU's cant be overclocked. So...... your probably SOL. Also like stated above, CPU's don't run at Max clock speeds all the time, the more demanding the task the more you get.
https://linustechtips.com/topic/1219859-i-need-help-asap/#findComment-13805279
