Seems like you are creating a few threads about building a new PC. How about you turn this thread into one for that purpose?
Tell us your budget, country, and intended uses for the PC, and we will give you full part list recommendations, everything from the case to the motherboard. You can edit your main post to include this info.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1219704-building-a-pc/#findComment-13801375
build around a z490 prime p and 10600k for 144hz
PCPartPicker Part List: https://pcpartpicker.com/list/T9ddRk
CPU: Intel Core i5-10600K 4.1 GHz 6-Core Processor  ($294.99 @ Newegg)
CPU Cooler: Scythe Mugen 5 Rev. B 51.17 CFM CPU Cooler  ($79.61 @ Amazon)
Motherboard: Asus PRIME Z490-P ATX LGA1200 Motherboard  ($159.99 @ Amazon)
Memory: G.Skill Trident Z 16 GB (2 x 8 GB) DDR4-3600 CL15 Memory  ($124.99 @ Newegg)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  ($117.99 @ Newegg)
Video Card: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card  ($409.99 @ Newegg)
Case: Cougar MX330-X ATX Mid Tower Case  ($50.98 @ Newegg)
Power Supply: EVGA BR 700 W 80+ Bronze Certified ATX Power Supply  ($74.99 @ Best Buy)
Total: $1313.53
Generated by PCPartPicker 2020-07-08 21:03 EDT-0400
something like this, left out budget for a storage drive, the cpu cooler is also a placeholder, i recommend a fuma 2, drp4 or d15, whichever's the cheapest. also thermal paste
 note that unless u need ur pc now, it's the worst time to buy a gpu/psu as far as i can remember. Still recommend waiting til rtx 3000, rdna2
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1219704-building-a-pc/#findComment-13801500
