CableMod PRO ModMesh RT-Series ASUS ROG/Seasonic Cable Kit - Black/White
Solved by Spotty,
10 minutes ago, RyanMattSerrafin said:Bridged means (e.g. for the GPU), instead of having 2 loose cables that plug into each 8/6pin, both of the cables are tied together to make it look much neater.
The kit does include cable combs but I believe for the PCIe connectors to the graphics card that each cable has its own cable comb. So it would be two bundles. I could be wrong though and they might include additional cable combs in the kit for such a configuration.
Cable combs are relatively inexpensive and assorted packs of cable combs can be bought on places like ebay or aliexpress for a few dollars. Or if you have a 3D printer you can easily make them yourself and I'm sure there are files for it available online.
