RTX 2080Ti SLI with Threadripper 2950x - Need help with SLI & PSU Wattage
Solved by Haro,
2 minutes ago, hitme987 said:can I do a NvLink/SLI setup with these 2 GPU's?
Technically yes.
But I wouldn't go with sli
Doesn't scale well in games and has almost no performance benifits
Unless you use a software that does
But in games, it's really not worth it.
2 minutes ago, hitme987 said:Will this PSU wattage be sufficient for my SLI setup
More than enough.
2 minutes ago, hitme987 said:Will I shorten my PSU life if wattage hits 850-950W during gaming
No for the most part.
