Hey guys , i,m in need of help, I'm a new gamer and just bought my first pc two weeks ago,i have an rtx 2060 super from gigabyte ,but my gpu is overheating when i play playing games like GTA 5 or Farcry5 ,
the temperatures rise upto 80*c.and keeps going up. i fixed the gta problem by changing my power management mode to adaptive, but for farcry 5 nothing is helping out .
my system specs are:-
1) Antec NX 310 case
2) Amd Ryzen 5 3600, with the standard cooler
3) RTX 2060 Super 8gb from gigabyte (2 fan variant)
4) Corsair vengence ddr4 ram 8gb >< 2
5) Gigabyte b 450 m motherboard
6) ant e sports fan (1)
i have three fans totally in the case, two that came with the case and one that i bought
the overheating happens even after i reduce the graphics to normal , but there is no change
i have one fan at the back of the case , one on the upper right corner and one in the front bottom
id like some help , cause im really lost and confused , if i've done something wrong
d1602277740b45239d729e41090cd741.MOV
https://linustechtips.com/topic/1217958-overheating-help-rtx-2060/
80c is not overheating and it's perfectly normal
Take the side panel off and if the temps go down significantly then it probably bad airflow.
Phone: Pixel 3a (Purple-ish).
Build Log:
I have that same model, it's normal for it to go past 80º (reaching up to 85~86º). Don't worry about it, the card won't die.
If you really care about temps, try to undervolt it and make a custom fan profile.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
