Hi ! So to start off here are my PC part.
GPU - 2080TI
CPU - I9-9900k
Motherboard - Aorus Pro
AiO - Corsair h110i
Ram - 2x16 Corsair Vengeance Pro RGB
PSU - EVGA 850W G2
M.2 SSD - Westerd Digital 1TB (I dont know the reference exactly)
***Case*** - NZXT H510 Elite
So I bought this PC about 1 year ago but back then i wasnt thinking much about performance/airflow. The thing is that i live in Canada so its pretty cool in my room in winter but now that summer has come its getting hotter and hotter. And with all the heat, i realized that my temp tend to go up (Around 82 for my GPU and 65 for my CPU). I know these temp are not damaging my card/processor but I would still prefer them lower just to make sure that my component stay in good shape for a longer time and to avoid any throttle.
I decided to buy a new case because mine only had 2 intake (for my rads) and 2 outake (1-120mm and 1-140mm) wich isnt great because the air coming to my card has been heaten up by my radiator .... i would like to get a new case on wich i could put my radiator (240mm) on the top so that the air coming to my card stay the coolest possible. The thing is that i dont know much about Cases/Airflow ... I guess a case with 3 front intake 3 top outake and 1 rear outake would be the best thing for me but i dont know wich one i should get. Oh and i would like it if i could put my PSU fan downside (so it had its ''own'' airflow / Sorry idk how to explain).
So i was wondering if anyone could maybe recommend me some cases to help me !
P.S. I do clean my PC often so its not a dust problem !
I am willing to spend up to maybe 225 USD (wich is roughly 300CAD)
Thanks ! And sorry for my poor english i actually speak french ^^'
https://linustechtips.com/topic/1217754-case-recommendation/
Fractal design meshify c
phanteks p300a or p400a
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784700
Just now, BlueScope819 said:
Your case doesn't really effect temperatures that much those are pretty normal. However, I'm sure @TofuHaroto would love to help you with case selection.
I know it wont reduce it by like 20C but maybe 3-4 C ? And maybe my fan would not be running at 95% all the time ? As i said i know nothing about Airflow .....
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784712
OHHH and i forgot to say that my top fan (140mm) cannot run higher than 40% because for some unknown reason whenever it gets higher than 40% my whole PC/Desk start vibrating soooo much its annoying ! I really dont know why and i don't feel like puting some weird and ugly antivibration tingy. I wanted to try a 120mm fan but the the specific fan i use are 120$CAD for one instead of 45$CAD for one right now ... (Thanks Covid-19 -_-)
Putting a weight in the middle on the top of my case in the middle of the fan reduces the vibration but it has to be an heavy weight and it doesnt work when it goes above 50% .... ^^'
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784721
1 minute ago, BlueScope819 said:
By your fan running at 95%, do you mean your graphics card fan or your case fans? If they are hooked up to the motherboard their speed changes depending on the temperature of your CPU, however the temps you described is pretty reasonable. I think you can fix the noise problem with fan curves.
I meant my Cases fan ! And i have set the curve myself with the NZXT software ! Whenever my card start getting warm the fan go faster (95% at 80C and 100% at 85C) so when i play some easy to run games my fan are really quiet, but whenever i play some Triple A game my PC sound like an Airplane. It doesnt matter much to me because i cant really hear it with my headset but id still like it to be a bit slower !
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784731
3 minutes ago, Intel Fanboy said:
Here is what i'd recommend for your case:
Fractal Design Meshify C
Corsair Carbide 275r
Phanteks Eclipse P4000a
Do you think that if i had my top fan set to 80-90% and my rear set to 80-90% my temp would go a little bit down (because right now my top fan is only at 40% like i explained above)
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784736
Just now, Intel Fanboy said:
Tu parle en francais? Bonjour. Comment vas tu? (I took french in high school I might not be super fluent.)
Hahahaha Yes ! Oui je parle français. Ça va plutôt bien, mais cela pourrait aller mieux si mes températures me satisfaisait ! Idk if you'll understand haha
Oh and since BlueScope said that my temps are probably not gonna go down with a new case, im wondering if he's gonna be able to tell me how to reduce them with my actual case (wich is amazing in terms of esthetic)
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784752
7 minutes ago, Intel Fanboy said:
Oui je comprends. You want lower temperatures in your case
Al right I'm a bit late to the party. Please explain how many fans you have right now, whether they are intake or exhaust, and what case you currently use. And what is this temps of? Explique sil vous plait
So basically my case is an NZXT h510 Elite
I bought it because of the esthetic (back then i didnt care about airflow and cooling) but with the summer heat i realized that i get higher temp (around 82C on my 2080TI). My case has a 240mm radiator as an intake. it also has 2 outake (one 120mm on the rear and one 140mm on the top)
The thing is that my GPU doesnt get much cool air since the air coming in the case gets warmer from the radiator so my GPU kind of get higher temps (worst in summer)
I also have my 140mm fan set to 40% speed max because if it goes any higher than that my desk start to vibrate like crazy ... i wanna try a 120mm to see if it changes anything but the price are just stupide right now because of Covid... And i really dont know WHY my top fan vibrate like this its annoying ...
This pretty much sums it up haha ! I doubt there is much i can do other than changing the case :/
Oh and my fan curve are already pretty agressive !
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784759
1 minute ago, Intel Fanboy said:
Mount the 240 mm radiator on the top of the case as an exhaust. You see the heat from the radiator is being intake and hot air is coming into the system, so mount the 240mm radiator on top of the case.
Put 3 fans on the front of the case for fresh air intake.
Put the radiator on top and more the top fan to the front. Buy and mount 2 more fans to the front of the case for intake. You might need fan splitters
In conclusion, keep the 1 exhaust fan in the back, mount the 240mm radiator on top, and mount the top fan on the front, and buy more fans to and mount them to the front of the case.
Yeah well thats the problem with my actual case ... The radiator cannot be installed on the top ... it can only be on the front. Also, you can only put 2 outake fan since there is only 1 rear and 1 top places where you can actually put them .... is stupid from NZXT because there is the space for a 2nd 140mm fan on top but yeah ....
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784767
This is not true, In my experience a case can make a HUGE difference in thermals. And if this were not the case the Steve over at GN would not thrash case designs for poor airflow optimization.
I have reduced temps by nearly 5-10 degrees C with my OC'd i7 8700k just by swapping cases and mounting my rad to the front of a mesh panel case.
I would recommend a front mesh panel case, some of these may require the purchase of additional fans. But you do not need to spend $300.
On the budget friendly side:
https://ca.pcpartpicker.com/product/zhjJ7P/cougar-mx330-g-atx-mid-tower-case-mx330-g
https://ca.pcpartpicker.com/product/Nhyqqs/bitfenix-nova-mesh-tg-atx-mid-tower-case-bfc-nvm-300-kkgsk-rp
Mid tier options:
https://ca.pcpartpicker.com/product/Q6YWGX/thermaltake-core-g21-tempered-glass-edition-atx-mid-tower-case-ca-1i4-00m1wn-00
https://ca.pcpartpicker.com/product/sY9tt6/corsair-275r-airflow-atx-mid-tower-case-cc-9011181-ww **
https://ca.pcpartpicker.com/product/pvdrxr/cooler-master-masterbox-td500-mesh-w-controller-atx-mid-tower-case-mcb-d500d-kgnn-s01 **
https://ca.pcpartpicker.com/product/3RJmP6/phanteks-eclipse-p400a-atx-mid-tower-case-ph-ec400atg_bk **
https://ca.pcpartpicker.com/product/ycbCmG/corsair-275r-airflow-atx-mid-tower-case-cc-9011182-ww **
https://ca.pcpartpicker.com/product/3nbwrH/thermaltake-versa-j24-tempered-glass-argb-edition-atx-mid-tower-case-ca-1l7-00m1wn-03
Premium $150+:
https://ca.pcpartpicker.com/product/nL7v6h/fractal-design-meshify-c-tg-atx-mid-tower-case-fd-ca-mesh-c-bko-tgl **
https://ca.pcpartpicker.com/product/Y6Crxr/fractal-design-meshify-c-atx-mid-tower-case-fd-ca-mesh-c-bko-tg **
https://ca.pcpartpicker.com/product/QdXYcf/phanteks-eclipse-p400a-digital-atx-mid-tower-case-ph-ec400atg_dbk **
https://ca.pcpartpicker.com/product/FP3mP6/phanteks-eclipse-p400a-digital-atx-mid-tower-case-ph-ec400atg_dwt **
https://ca.pcpartpicker.com/product/KnWrxr/phanteks-ph-es515ptg_swt-atx-mid-tower-case-ph-es515ptg_swt
Premium $200+:
https://ca.pcpartpicker.com/product/xBVD4D/fractal-design-meshify-s2-white-tg-atx-mid-tower-case-fd-ca-mesh-s2-wt-tgc
https://ca.pcpartpicker.com/product/VvJtt6/fractal-design-meshify-s2-black-dark-tg-atx-mid-tower-case-fd-ca-mesh-s2-bko-tgd
https://ca.pcpartpicker.com/product/M3kj4D/cooler-master-mastercase-h500p-mesh-atx-mid-tower-case-mcm-h500p-mgnn-s10
** Personal favorites and known for good airflow performance.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784770
Mid tier options:
Premium $150+:
Premium $200+:
Okay but my CPU temps arent that bad since the rads is already has an intake. But would my GPU get a bit cooler with a 3rd bottom fan bringing in some fresh air that hasnt been heaten up by the rads. With 4 outake fans too !
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784775
NZXT cases don't always have best airflow. This is why you should look at like a Meshify C or Corsair case. Mount the radiator on top, keep 1 exhaust fan in the back, and have 3 intake fans.
But will the CPU temps get higher if my radiator doesnt get some fresh ? Not that my CPU temps are bad (65-70C for an i9-9900k for 4-5 hour of gaming is actually pretty okay i think) but if its gonna get hotter by like 10-15C i doubt i will like it hahaha ^^'
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784778
If you got a mesh panel case CPU temps would drop. And it would be unlikely that a 3rd 120mm fan would fit, the rad interferes with that, you could consider a push-pull fan config on the rad though, depending on the case length and your GPU length it could be a good option.
9 minutes ago, Intel Fanboy said:
I agree NZXT cases don't always have the best airflow
Yeah they do not, I am starting an new ITX build in the H210 and I am heavily modding the front panel to allow for proper airflow, + a push-pull fna config on my rad.
11 minutes ago, Intel Fanboy said:
Like the Meshify C or at least something here the front panel has holes for intake like Corsair 275r
Yup Meshify C is great, I own it. I'd say the other best option is the Phanteks P400A, 275R is pretty decent too.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784793
But ive seen a couple of Linus/Jays video where they have a 240mm rad + a 120mm fan ont the front ?? :o
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784796
Depends how large the case is. I mean I don't remember seeing that in any of their vids, but I could have missed it. In a large full tower case sure, but in a mid tower that only just fits 3x 120mm fans it may not be possible as the rad has overhang on the ends and is not exactly 240mm long, that is just the size of the fan mounting. The H100i rad is closer to 270-275mm long.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784802
So with all the information you guys told me there is 2 option for me right now
Option 1 : I would buy the Kraken X53 (For another problem) and i would get the Fractal Design Meshify C. I would put my radiator on the top and 3 Intake 120mm fan with 1 outake 120mm fan on the back
Option 2 : I would Buy the same component but (if i actually can do it) i would put the 240mm Rads on the front with another 120mm Fan under it and i would put 3 120mm fan for outake (2 on top and 1 on the back)
Option 3 : I keep my case and my cooler but i try to find a way to put my 140mm outake on the top to run at 80-90%
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784803
Oh okay ! But is this gonna affect my CPU temps or are they gonna stay pretty similar ? Since the air cooling the rads isnt gonna be fresh air ?
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784804
Option 1 or 2 IMO.
Adding a 3rd 120mm fan to the front would only affect GPU temps, not the CPU, A push/pull fan config is still the best option though.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784813
Tbh im lazy ... i dont feel like doing a push/pull haha !
But i think you might have missunderstand my question ^^' I was asking if putting my Rads on the top has an exhaust instead of on the front has an intake would make my CPU temps go higher ? Because right now my Rads gets cooled by the air outside my case and its around 65C Max. So if i put my rads on top the air cooling it would be the air inside my case wich is actually warm air, so would this actually affect my CPU temps a lot or not ?
Sorry my english is soooo bad ^^'
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784816
Haha fair enough.
No worries lol, yeah I misunderstood.
Yeah CPU temps will rise if you mount the rad to the top of any case. Depending on the case and airflow setup this can vary, for me it was a 5-10 degrees C difference.
My Builds:
MEGA Desk Build
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784820
Ok ! I know what i need to do now haha Ill buy a new case and try some different set up ! Thanks for the help to you and everyone !
 I might just buy a full tower too ^^' its not like i carry my PC around at all !
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13784824
GPU - 2080TI
CPU - I9-9900k
AiO - Corsair h110i
PSU - EVGA 850W G2
get a phanteks p400a digital   or   a be quiet 500dx   or   a cooler master td500  or  a CM nr600 with two fans. The meshify C was the best case you could get, but now, it's overpriced garbage that gets beaten by the p400a, the 500dx and the td500
It is but human, to err, to buy a PSU, akin to dirt,
but fret not, young Padawan, for we will tell you,
what will become, of that, which you have earned
https://linustechtips.com/topic/1217754-case-recommendation/#findComment-13789387
