Hi,
i finnaly decided to build a new pc,
My current PC:
CPU: i5 -6500
MOBO: Z170 ( yeah i know i wanted to upgrade)
GPU: R9 390
RAM: HyperX 2133MHz
PSU: Corsair CX650M
SSD: Crucial 64gb 1f641.png:(
HDD: WD 1TB Cavier
CASE: Deepcool Kendomen
Monitor: BenQ GW2470
but can't decided between two configuration that i made. Please note that PC parts are a little limited at the moment in my country.
First
CPU:  Ryzen 3700x        356$
CPU Cooler:Gamer Storm Castle 360RGB V2      141$
MOBO:MSI X570 Gaming Edge      244$
RAM:Trident Z RGB NEO 2x8gb 3600MHz      135$
GPU: MSI RTX 2080 Super Gaming Xt Trio         959$
PSU:Riotoro Enigma G2 650W 80+ Gold         104$
SSD: Samsung M.2 NVMe 970 EVO 1 TB        256$
CASE:MSI MPG Gungnir 100 ARGB     106$
Monitor: MSI AG32CQ     428$
Total: 2729
Second:
CPU Cooler: CoolerMaster ML240R       113$
MOBO: Asus Rog Strix B550-F    225$
RAM:A-Data 2x8gb XPG Spectrix D60G 3600MHz   137$
GPU: ROG Strix RX5700XT O8G Gaming   602$
PSU: Cooler Master V650 Gold     143$
CASE: Asus TUF GT501 TUF Gaming  143$
Monitor: ROG Strix XG32VQR Curved   652$
Total: 2627$
Thank you very much for taking the time to go through this.
https://linustechtips.com/topic/1217614-need-help-deciding/
In all countries, pre-covid stocks are diminishing.
- Get a corsair PSU
- That B550 is very expensive, X570 ftw.
- Add some HDD, 3 or 4TB, 1tb ssd won't be enough.
https://linustechtips.com/topic/1217614-need-help-deciding/#findComment-13783524
streaming? if not then go amd. also i wouldn't go with the 2080 super. change either for 2080 or 2070 super. you will get lesser fps boosts with the 2080 super. that extra money is better spent elsewhere.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1217614-need-help-deciding/#findComment-13783554
- Get a corsair PSU
Hi thx for the reply,
There are no Corsair PSU 's available at the moment
i have one 1TB HDD plus that i can add to the system
My main problem is too choose between MSI and ASUS,
https://linustechtips.com/topic/1217614-need-help-deciding/#findComment-13783562
Hi, thx for taking the time
I have a capture card so that i think is not a problem. I never used a NVIDIA card so dont know how to that works. So thank you.
But sadly there are no 2080 cards in stock and wont be for a long time :(
https://linustechtips.com/topic/1217614-need-help-deciding/#findComment-13783576
Both are good brand, but for that much money i think you should get the better one.
https://linustechtips.com/topic/1217614-need-help-deciding/#findComment-13783579
Specification and Performance wise both mobo are in same level. One being a slight cheaper than the other, we get almost identical output from both . But being more latest, i would prefer to have Asus ROG Strix B550-F for my build.
https://linustechtips.com/topic/1217614-need-help-deciding/#findComment-13783656
Thank you i will take that into consideration
https://linustechtips.com/topic/1217614-need-help-deciding/#findComment-13783881
