So I have seen many posts saying that the Intel AX200 M.2 Wifi 6 Wireless Adapter does in fact work with AMD systems (Including my Ryzen 5 3600). Here are my parts:
OS: Windows 10 Pro 64-Bit (ver 1909)
CPU: Ryzen 5 3600
MB: Asrock B550 Phantom Gaming 4
NIC: Intel AX200 Wifi 6 (802.11ax) Adapater
I was worried at one point that the wireless card is not compatable with my AMD chip because of the warning on the amazon page I bought it from, but later found out that is not the case. I have updated all of the drivers I could find and get my hands on. Unfortunately, that has not fixed my issue. Does anyone know why this is?
https://linustechtips.com/topic/1217105-intel-ax200-wireless-adapter/
Do you have antennas plugged in?
