PC not posting, only gives debug light
Go to solution Solved by Haro,
can't necessarily see it at such angle
re seat the cpu
try clearing the cmos and inspect the cpu by looking at it from it's side
So I had a ryzen 2600 and a 1060 but upgraded to a 3800x and a 2060.
I already updated the bios on my MSI B450i gaming plus ac so that it could support the 3800x via usb flash.
My 2600 and 2060 worked just fine before I tried changing out the cpu to the newer one.
When I took out the cpu it took a bit of force because it was stuck to the cooler which i got it unstuck with a slim knife but I did not pull out the lever of the socket.
I plugged everything in when my pc would not boot, and I only got a single flash of the light on the cpu for the debugging tool.
-note my user manual says that the cpu light means its bad or not recognized
Things I've tried:
trying one of each ram
making sure the power button cords are plugged in
trying both the 2600 and the 3800x
replugging the ssd and hdd I have
putting paperclip on cmos to short it out for 15sec without power
Ideas:
I have a feeling that the problem is that the socket broke for the amd cpu but unlike intel motherboards, the amd motherboards only have gold points, not bendable pins so I don't really know what else could be the problem.
A validation of my claim or anything to try or think about would be much appreciated :)
Picture of my 3800x:
https://imgur.com/Oz0vbsT
https://linustechtips.com/topic/1216768-pc-not-posting-only-gives-debug-light/
re seat the cpu
Phone: Pixel 3a (Purple-ish).
Build Log:
What PSU?  You’re drawing a lot more power after the upgrade than you were.
re seat the cpu
I tried it again but to no avail.
I cleared the cmos with a paper clip and tried the old cpu but still the same thing.
I also saw the side and I think it is good, it looks like my 2600.
6 minutes ago, b33pimajeep said:
I have a 700w psu and I checked online that even a 550 should be good still via pcpartpicker
That should be fine as long as the PSU is still good.  They wear over time.
