Well, my dog got a little too cueious about my rig and ate my perepherals or at least tried to. yanked it right out the 2 case usb ports. one is bent out of shape the other is missing the top half in side. so the latter is likely a dead port.
 since my keyboard and mouse wires are short the front of the case usb placement matters a lot to me reaching the board easily.
since this thread is about modding, i figured replacing usbs or adding them may be a thing. how would a newbie even begain to go about fixing a dead port? thanks.
edit: found the other half of the usb. its in the end of the mouse.
main rig:
CPU: 8086k @ 4.00ghz-4.3 boost
PSU: 750 watt psu gold (Corsair rm750)
gpu:axle p106-100 6gbz msi p104-100 @ 1887+150mhz oc gpu clock, 10,012 memory clock*2(sli?) on prime w coffee lake igpu
Mobo: Z390 taichi ultimate
Ram: 2x8gb corsair vengence lpx @3000mhz speed
case: focus G black
OS: ubuntu 16.04.6, and umix 20.04
Cooler: mugen 5 rev b,
Storage: 860 evo 1tb/ 120 gb corsair force nvme 500
backup
8gb ram celeron laptop/860 evo 500gb
https://linustechtips.com/topic/1216153-replacing-dead-case-usb-ports/
The easiest solution would be a front panel 5.25" hub,
https://www.amazon.com/Hima-Computer-Expansion-Microphone-Suitable/dp/B082F5M1NZ/ref=sr_1_10?crid=15IJ0F7VQB395&dchild=1&keywords=front+panel+usb+3.0&qid=1593505542&sprefix=front+pa%2Caps%2C324&sr=8-10
You could also try contacting Fractal to see if you could buy a replacement front I/O board.
Depending on your soldering skills it may be possible to replace the ports on your current board.
