I have fiber internet connection in my house it works without any problem everytime I use it.
But when my friend comes home with his laptop and connects it to our internet every single device losses internet connectivity this happens only with his laptop can someone tell me what's wrong
https://linustechtips.com/topic/1215705-wierd-network-problem/
-= Topic moved to Troubleshooting =-
Please give more information, there is not enough there for us to help properly diagnose the issue.
What device does your friend use?
What router or modem are you using on your network?
Does he use the wireless or a hardline to connect?
Please add as many details as possible, this will help the forum in the best way in helping you.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1215705-wierd-network-problem/#findComment-13768034
Laptop
DBC Router
Both Lan and WiFi does the same.
https://linustechtips.com/topic/1215705-wierd-network-problem/#findComment-13768123
5 hours ago, SladeDJWilson said:
I close all the torrents but he runs some IDM app
It sounds like there is a possibility that the IDM app is Malware, which is hitting the network performance somehow.
Jacob H.
Northern Alabama
Associates Degree - Information Systems
Primary Job: Technology Specialist / Financial Industry
Primary PC (Laptop): Dell XPS 9570 (Core i5 8th Generation, 16 GB RAM, NVIDIA 1050 4GB, 500 GB SSD, 1TB HDD)
https://linustechtips.com/topic/1215705-wierd-network-problem/#findComment-13768832
