If you want then you'll get cooler results but you will get way louder ones
Keep the side panel on if temps are within reason
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1214979-cpu-temps/#findComment-13762801
I'd remove, clean and repaste the cooler. I was getting 80-85C at 4.2ghz all core at 1.25V while looping cinebench with my 3600. Gaming temps were in the low 70s.
Buy a tube of decent paste. They aren't too expensive. I like Noctua H2 but any popular paste is fine.
*Edit* If I were you, I'd seriously consider investing $30-$50 in a decent cooler for it. The stock cooler for the 3600 is junk.
https://linustechtips.com/topic/1214979-cpu-temps/#findComment-13763790
@Demonic Donut @5x5 My pc is brand new, I bought it 4 days ago, I get 50-55 *C while running chrome and 70-75 *C while gaming ( on 3700mhz 1.15volt on a 240Hz monitor).
Before I clocked it (when it wasn't tunned), it was reaching 75-77 *C on chrome(On 60Hz monitor).
https://linustechtips.com/topic/1214979-cpu-temps/#findComment-13764062
Something is seriously wrong with your cooler mount.
https://linustechtips.com/topic/1214979-cpu-temps/#findComment-13764251
Did you build it or was it a prebuilt? If you built it four days ago there is a good chance your thermal paste is plenty wet still and you could try to remount without new paste. I would pull the cooler, look at the paste application and if it looks decent, replace the cooler and give it a gentle twisting motion before securing it.
Also, when you pull the cooler you will probably remove the CPU with it. Just be aware.
https://linustechtips.com/topic/1214979-cpu-temps/#findComment-13764419
