Budget (including currency): 600-800
Country: uk
Games, programs or workloads that it will be used for: gaming, recording, work
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): prefer to buy on Amazon
https://linustechtips.com/topic/1214943-first-build/
Country: uk
Gaming is pretty well defined but recording and work arent.  Recording could be lots of things as could work.  Which is the most important and what does it entail?
https://linustechtips.com/topic/1214943-first-build/#findComment-13762487
Or, if you can't go overbudget at all:
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1214943-first-build/#findComment-13762528
19 minutes ago, Picxles said:
Recording my gameplay
So streaming.  Couple of ways to go about doing that.  One is Nvidia 1660.  Sounds like you’re covered.
https://linustechtips.com/topic/1214943-first-build/#findComment-13762544
