1 minute ago, bassprowler said:
I have a amd 2700x and two msi nivida gtx 1070 x gaming graphics cards im trying to sli bridge them and it doesnt seem to be working i tried everthing i dont know if the motherboard can do sli.
have you verified that the motherboard has SLI support?
https://linustechtips.com/topic/1214649-help-with-sli/#findComment-13760186
There's a pretty simple way of checking that: go to your motherboard's manufacturer's website, find the mobo there and read if it supports SLI or not.
https://linustechtips.com/topic/1214649-help-with-sli/#findComment-13760188
Crossfire only...
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1214649-help-with-sli/#findComment-13760195
HTFO... that's the same 'board as me...!
There's TWO 12V headers on that 'board - one behind the rear audio I/O stack & one bottom-left corner, by the HD Audio header..
N/m; wrong thread
WHY NOT...?!
https://linustechtips.com/topic/1214649-help-with-sli/#findComment-13760223
