6 minutes ago, Macka09 said:
Hi guys. I’ve just completed my new build and I’m completely new to pc gaming so I don’t really know what I need to be using to have maximum frames and smoothest gameplay. Can anyone advise please? I’m sat at 120fps in the menus at the moment.
Many online gamers use native resolution, High texture quality and low settings for visibility in game.
Benchmarks usually show Ultra presets, you'd have to do a manual search like "Warzone 2070 Low settings" and swap keywords to find specifics.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
What resolution are you playing on?
9 minutes ago, Macka09 said:
1440p.
Texture quality High, Most selectable variable settings on Low. Gain what you can...
Then use Nvidia FX-Tools to increase visibility at a small performance cost.
You know your 120fps in Menu's, what about in game?
1 minute ago, Macka09 said:
I haven’t been in there yet lol. I’m trying to get my headset working lol I’m using my steelseries that I use with Xbox but it won’t work lol
There is probably a guide someuser has made..
Its all about the google search keywords..
Xbox Steelseries headset not working on pc
