Having a stereo amp output a mono signal
Solved by jaslion,
Just now, German_John said:Sorry, I should have made it a bit more clear. I saw that article, too.
My question was whether the way I think it works would actually work, i.e. taking the inputs on the board, soldering the resistors to each, then soldering those together and to one of the outputs.
Pretty much. That's pretty much how the instructables does it too. It's an analog signal those can be combined this way. You may have some quality loss sure but if that's your concern just get one of the dozens of cheap boards out there that do some processing to avoid any issues.
