Budget (including currency): 120,000 INR
Country: INDIA
Games, programs or workloads that it will be used for: Primarily Gaming, Coding
COMPLETE SPECS
PCPartPicker Part List: https://in.pcpartpicker.com/list/hwz3Dx
CPU: Intel Core i5-9400F 2.9 GHz 6-Core Processor  (₹13350.00 @ Amazon India)
Motherboard: ASRock B365M Pro4 Micro ATX LGA1151 Motherboard  (₹8799.00 @ Amazon India)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory  (₹7605.00 @ Newegg India)
Storage: Crucial P1 1 TB M.2-2280 NVME Solid State Drive  (₹11800.00 @ Amazon India)
Video Card: Zotac GeForce RTX 2070 SUPER 8 GB MINI Video Card  (₹43100.00 @ Amazon India)
Case: Corsair SPEC-01 ATX Mid Tower Case  (₹3149.00 @ Amazon India)
Power Supply: Gigabyte B-H 700 W 80+ Bronze Certified Semi-modular ATX Power Supply  (₹4988.00 @ Amazon India)
Wireless Network Adapter: TP-Link Archer T4E PCIe x1 802.11a/b/g/n/ac Wi-Fi Adapter  (₹1699.00 @ Amazon India)
Monitor: BenQ ZOWIE XL2411P 24.0" 1920x1080 144 Hz Monitor  (₹16490.00 @ Amazon India)
Keyboard: Redragon K551 Wired Gaming Keyboard  (₹3000.00)
Total: ₹113980.00
WHERE I NEED ADVICE/HELP:
I know this will bottleneck, but still gives out great FPS.
Is bottleneck a bad thing in the long term? I might upgrade to a better CPU in the future but as of now I don't want to get a lower performing GPU than the 2070 SUPER.
I am a total noob and open to all suggestions, do correct me if I am wrong here.
Thanks in advance. :)
https://linustechtips.com/topic/1212711-1st-ever-pc-build-please-help/
You can't get the newer Intel chips? They're much better.
Otherwise I'd go Ryzen.
I don't think the T4E has Windows 10 support for the utility, so you'd be stuck just using it barebones. Still works, you just don't have access to tweaking anything.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Country: INDIA
COMPLETE SPECS
So for your budget is about like £1200, you could easily get a decent ryzen build correct me if there are any different prices in your country
CPU: Ryzen 5 3600
GPU: Gigabyte gtx 1660 Super oc 6g
Mobo:MSI b450 tomahawk max
RAM: 32gb ddr4 lpx vengeance 3200mhz
Storage: WD sn550 1tb, Baracuda 2TB HDD (*In use), Hitachi 2tb HDD, WD 0.5tb HDD (both HDD knackered)
PSU: cxm 450
Case: Corsair Carbide Series
CPU: Ryzen 5 3600
PSU: cxm 450
@Skyte the storage options can be changed if you want something different
CPU: Ryzen 5 3600
PSU: cxm 450
