2 minutes ago, HaleWhales said:
Anyone know how to run minecraft off of a usb drive so i can switch it between my 2 pcs and just play
You could try copying all of the game files onto it. I have no idea if that will work but it's the only way i think sounds plausible.
(for future reference, make a better title so people know what you need help with without clicking on your post)
https://linustechtips.com/topic/1212674-need-help/#findComment-13744591
Is there a reason you can't just download it on both PCs? It's not a very large game. If you can't, maybe just get a small cheap SSD and use that? I don't know about USB.
https://linustechtips.com/topic/1212674-need-help/#findComment-13744597
