looking for 3.5mm audio parts to repair headphone
keysbeast13
Since radioshack has been gone for some years now and i have not needed to really fix anything i havent minded. But now my male audio plug is giving out and what sites now are good for buying audio parts from.
well i dont know where you live, but do you have frys nearby. if not there is always amazon/ebay although for electronic parts i usually buy from aliexpress or banggood.
Amazon should have whatever you need. If it's a specific part maybe check the manufacturer or company website
i live in sw Pa and theres no real places for parts ill check out alie express but reufes to give jeff any money thanks
If it's a specific part that I need, I'll go through mouser or digikey.
If I'm looking for something generic, headphone jack or wire, I'll go though ebay or amazon.
For audio connections I like Neutrik/Rean, which are easily found on ebay. I think I have some switchcraft around here too, and they are on par with Neutrik.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
