https://linustechtips.com/topic/1212108-first-pc-build/
looks pretty good, would get a better case for more airflow though
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1212108-first-pc-build/#findComment-13740404
looks pretty solid, i'd agree w/ youngboy that you should probably get a 1tb ssd if you can. and my standard disclaimer about that case applies, the usb c on the front won't work unless you get a special adapter that's like $15-20 USD. (i say this as someone who plans to get that case, not really a huge deal just something you should know)
CPU: AMD 3600X
GPU: Nvidia 3070 (planned)
motherboard: MSI B500-A PRO
memory: G Skill Ripjaws V 2x8 GB 3600Mhz CL16
PSU: EVGA B3 650@
Case: NZXT H510
wireless network adapter: intel ax200
https://linustechtips.com/topic/1212108-first-pc-build/#findComment-13740409
-= Topic moved New Builds and Planning =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1212108-first-pc-build/#findComment-13740620
I would personally go for 2tb SSD, it's cheap enough nowadays. Makes sure that you won't run out of space for your games and doesn't cost that much (like 50-100 bucks more if I'm not wrong). Should serve you well in the long run. Also I'd go for Ryzen 3700x for the processor, makes it much more futureproof. 6 cores vs 8 cores and all that. New games will start to utilize those cores when the new consoles come so going with a 6 core right now seems... lacking. Of course this will cost you more but I think it will futureproof your machine a lot, so in the long run seems worth it for me, personally.
E: If you don't need the computer right now, the new GPUs from nvidia and amd are gonna come out later this year so that should make the last generation GPUs come down in price. You could grab one of those too.
https://linustechtips.com/topic/1212108-first-pc-build/#findComment-13740621
nah go with 1 TB SSD and 1 TB HDD or with 512GB ssd and 2 TB HDD. Your setup it looks pretty solid maybe some case fans but they can come later. But get a better cooler than the stock amd. The thing is when you want to backup because windows just does shit and you need to reinstall it you can have the important stuff on the hdd and just reinstall windows without looking into buying more Storage just to backup your stuff.
Ryzen 7 3700x with pins Soldered Back on it.                         80€
Asus ROG Strix X570 E Gaming + 32GB Ballistix Sport Ram  300€
Sandisk Extreme Pro 1TB                                                       80€
RTX 2060 Super        250€
Samsung 870 QVO 1 TB                                                        70€
https://linustechtips.com/topic/1212108-first-pc-build/#findComment-13740657
You know, 1 game today might take up to 100gb (or more) of hard drive space. If you want 10 of such games installed, that's your SSD maxed. I would go for 2tb. Just my 2 cents.
https://linustechtips.com/topic/1212108-first-pc-build/#findComment-13740820
I don’t really need more than 500gb SSD, I use a 1tb hard drive to store my photos, videos, movies and such. For games, I don’t have more than 3 on my pc and for that I don’t see a reason to spend another 150$ for storage space.
https://linustechtips.com/topic/1212108-first-pc-build/#findComment-13740905
Then that's the best for you. I said my 2 cents ;)
https://linustechtips.com/topic/1212108-first-pc-build/#findComment-13741066
but are you palying 10 games frequently? The games you are playing more often you can put on the ssd. Its his PC i just wanted to say what i wanted to say. He can put 20 games on his 2 TB HDD and if we Calculate it it would be 30 Games so....
RTX 2060 Super        250€
https://linustechtips.com/topic/1212108-first-pc-build/#findComment-13741596
