How does load balancing routers work?
Go to solution Solved by BrinkGG,
Just now, kaanimo said:
So, I'm much experienced with networking so I didn't quite understand what I found on Google searches. I know that you need more than one internet connection (thus more than one modem) and you connect them to the router. Then I also understand that you can use one connection mainly and have the other connection as a fail-over.
But my the thing that confuses me is can you use two connections with the same client to achieve more up and down speeds. For an example, I have two 100/10 Mbps connections and I plug them into a load balancing router and boom I have 200/20 Mbps on one client. Or is it just one 100/10 connection to one or more clients (for an example one computer) and one 100/10 connection to other clients?
So for your example, here are the options you would have for conventional load balancing:
Failover LB: One connection is used all the time, and only when that first connection can't handle the entire network's bandwidth is the second connection used.
Weighted Split LB (50/50, 60/40 or similar): The first connection used until it hits a preset load limit, then it will start using the second connection till both are at limits, then both will increase above that to meet the load need.
unweighted Split: Both connections are used as close to equally as possible.
     All of the above can only use the maximum of ONE connection per client. (2x 100/10 connections, one client can only hit 100/10 at max unless it's split workloads like torrenting)
Pure split (Rare): "Bonded" connections that allow for full usage of multiple connections, splitting packets evenly and reassembling them before reaching their destination.
This is talked about in this LTT video:
Hope this helps! If you have any other questions, feel free to ask.
So, I'm not much experienced with networking so I didn't quite understand what I found on Google searches. I know that you need more than one internet connection (thus more than one modem) and you connect them to the router. Then I also understand that you can use one connection mainly and have the other connection as a fail-over.
https://linustechtips.com/topic/1211612-how-does-load-balancing-routers-work/
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
Another thing to take into consideration when doing something like this is that you should have at least 2 different ISP sources. It makes no sense to have 2 connections from the same ISP as if they have a failure at their end, both connections are likely to fail which defeats the purpose of failover.
