Dual radiator loop order
Solved by W-L,
Just now, JohnGamez said:I'm making a loop for the first time and im not sure which loop order to do. The parts I'm using are: a gpu block, CPU block, 2 rads and 2 pumps
The order of the loop doesn't matter since the fluid moves around the loop at such a fast rate. Only thing that needs to be consider is the reservoir being placed above and before the pump so it doesn't run dry. Also for a single GPU and CPU loop a single good quality pump like a D5 of DDC is more than enough, other than to have a secondary unit for redundancy purposes.
