Hey all!
I'd like to replace my current air cooling setup in my case to something more effective. Not that its currently bad, but I want to do better.
I have a Cooler Master H500 case with the following config;
240mm AIO on the CPU, front mounted, push/pull with 2x 200mm fans on the outside and 2x 120mm fans on the inside.
3 x 120mm fans for exhaust (2 in roof, 1 at back).
Fans are 120mm Antec Prizm fans and the 200mm fans are the CM stock with the case.
Mobo is the X370-F with 7x 4 pin fan headers.
Should I just buy 5x Noctua 120mm fans and plug each into its own header?
Feedback on what I can do to make this the most effective and cool system possible is appreciated
SETUP:
  • Ryzen 9 3900XT @ 4.3 all core (peak core voltage 1.3)  (water)
  • 2x8GB TeamGroup 8Pack Ripped Edition 3600mhz CL14
  • RTX 2080ti OCd @ +150 core, +1000 memory (water)
  • Aorus B550 Elite (rev1)
Personal Bests:
  • Cinebench R15: 1785  1883 (Aug 2020)
  • Cinebench R20: 4136  4243 7125 7550 (Feb 2021)
  • 3DMark/Time Spy: 10,238 13,106 13,993 14,149 15,295 (Feb 2021)
Build Log: https://linustechtips.com/topic/1314971-the-ultimate-noctua-pc-15-fans-custom-loop-case-mods/
https://linustechtips.com/topic/1211212-ultimate-air-cooling/
Mesh front version of the case?
Desktop benching:
https://linustechtips.com/topic/1211212-ultimate-air-cooling/#findComment-13733340
Is the case one of the mesh front versions...?
If not, is the mesh front available as an optional extra?  Might help...
EDIT:
@Jurrunio Looks like the non-mesh version should come with the mesh front in the box as an option...
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1211212-ultimate-air-cooling/#findComment-13733345
27 minutes ago, Eighjan said:
EDIT:
Early versions don't, it's only media outlash on how bad the solid front is that CM started sending out mesh fronts within the box.
Desktop benching:
https://linustechtips.com/topic/1211212-ultimate-air-cooling/#findComment-13733449
EDIT:
Mesh front, 100% I threw the acrylic front in  the attic.
SETUP:
Personal Bests:
https://linustechtips.com/topic/1211212-ultimate-air-cooling/#findComment-13733469
Oh it was horrible
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1211212-ultimate-air-cooling/#findComment-13733470
Can confirm, mesh front on case.
Or else I'd be buying a different case, too :P
SETUP:
Personal Bests:
https://linustechtips.com/topic/1211212-ultimate-air-cooling/#findComment-13733484
I'd say just ditch the AiO & put an NH D14 (or similar) in it's place.
WHY NOT...?!
https://linustechtips.com/topic/1211212-ultimate-air-cooling/#findComment-13733499
