ryzezn overclocking single core boost problem
Go to solution Solved by boggy77,
2 minutes ago, thenormalguy134 said:
i have tried ryzen master but i can't figure it out kinda, can have for example. 3.9-4.1 base and 4.4 boost in ryzen master?
not sure you cn set base and boost in ryzen master, just fixed frequencies. if you want to get as much boost and base as possible, just enable pbo in bios.
i got a 3600x and a b450 asus strix mobo and im trying to overclock, but when i change the multiplier my clock drops down to base with all core overclock, and thats fine, but it disables single core boost, how do i eneble single core boost again after overclock?
How much faster than 4.4GHz do you want a 3600X to go...?
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
That's 3900/3950X territory... you're gonna need highly specialised cooling for that.
Zen architecture isn't intended to be overclocked in the way that Intel chips are...
WHY NOT...?!
im fine, got 240mm aio
I'm talking dry ice/LN2... if you wanted those clock speeds, easily, you shoulda bought Intel.
WHY NOT...?!
First of all
Ryzen does not benifit a whole lot with over clocking
Just enable pbo and it will probably do a better job than what you can now
2nd over clocking memory will probably be more beneficial than over clocking the cpu
Phone: Pixel 3a (Purple-ish).
Build Log:
Single... overclocking AMD CPU's from the last 5yrs isn't a 'fast & loose' affair like it is w/ Intel.
WHY NOT...?!
1 minute ago, GoldenLag said:
Not happening on safe voltages or sane cooling solutions.
Doubtful even the best CCX you can get can do that much.
... and certainly an iffy proposition on B450.
WHY NOT...?!
20 minutes ago, thenormalguy134 said:
manual?, so i can have boost with auto overckocking?
generally, for gaming it's better to just leave pbo on and let it boost, as games benefit more from boosting just a few cores.
for multithreaded workloads, such as rendering, it's better with an all core manual oc.
in ryzen master you can do per core manual oc, having a few cores higher and a few cores lower. but that's not really boost, but still a manual fixed overclock, and you can't guarantee the game will choose to run on the higher clocked cores.
