Recommendations for thin 120mm radiator fans
zogthegreat
Hi everyone!
As the title says, I'm looking for recommendations for thin 120mm radiator fans for my build. I currently using Arctic F12 PMW's but I would like to put something thinner on my system.
Thanks!
zog
(EDIT) Also, are there any software controlled fan controllers out there?
Sorry this is no answer to your question.
How are the Artics? I'm thinking of buying the 5-pack for a new build
Windows 11 Pro 22H2
Ryzen 3600
Gigabyte B450M DS3H
GIGABYTE RTX 2080 GAMING OC
G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory
@jonahadami, Personally I love the F12's. Super quite and I've never had one go bad. I just picked up another 5 pack of them myself for $35 on eBay.
I know that the Noctua's have a better reputation, but IMO their colors suck and they are about twice the price of the Arctic's.
Scythe has some very slim fans I believe. They are not the quietest tho but you can always undervolt them a little
Folding stats
Vigilo Confido
They are flawless, especially for the money. If 20 usd for a single fan doesn't sound right to you, arctics are probably the best choice.
noctua nf a12x15? Raijintek used to be the go-to brand for slim fans. I'm sure scythe has a few too.
Btw they are much less effective than 25mm thick fans.. Unless those are the only fans that fit, don't use slims.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
Thanks @00RaZoR11! The Raijintek's look like what I need:
https://www.raijintek.com/en/products_detail.php?ProductID=14
