USB-C 10-GiG-E Ethernet Adapter
AquaVixen
As the title says I'm looking for a USB-C 10-GiG-E Ethernet Adapter for a future build. Does anyone know of any such adapter that exists? I'm looking for a USB one, NOT a thunderbolt one.
There are some that go to 2.5/5 Gbps but not 10...from what i understand about the interconnects, USB-C does not support 10 gig lan because of the poor latency.  You need to go to TB3 for that.
It should be possible. There is both a 20 Gbps and 10 Gbps standard for USB 3.2 Gen2. Even the 10 Gbps standard should be "Enough" to run 10 Gigabit Ethernet.. which is also 10 Gbps. At least logically that should work? 10 Gbps = 10 Gbps.
if its a desktop just use PCIE it is going to be easier.
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
its also about power and someone making a chip that will work over USB
I was planning to use this in a ITX build that does not have a spare PCIE port. The PCIE port in the planned build would be using a raid card in there. I guess I can't have everything I want in technology just yet. :(
So then no one has created a chip that can do what I asked for yet? Okay. So that's the answer then.
Well that is a very simplistic arguement. Take into account an interface chip and latency. With overhead, 10 gig ethernet would be more like 6Gbps, hency there are 2.5/5 gbps adapters.
many boards now should have 2.5 or 5gb built in
Yep but I wanted 10 Gigabit.. oh well. :(
then DTX or mini ITX.
some server boards will
I'll add this for a NAS/server USB nics aren't reliable
Oh! I forgot server boards. I wonder if supermicro makes ITX AMD boards.. time to go looking. :D Thanks for reminding me.
what socket?
what socket?
I'm hesitant to start driving this topic into a discussion about motherboards because this is the wrong section of the forums for that. I think my original question was answered already here.
just give is more info. it is fine. its moved to more what you need
I was hoping to build a small server out of a AMD AM4 B550-based Mini-ITX build, mainly because the new 4000 series APU's will feature 8 cores and 16 threads at < 100W. Which is very very appealing to me. I'll be replacing an ancient Dual-Quad-I7-Xeon-LGA-1366 server. I was wanting to use a hardware raid card in the main PCI-Express slot and then try to find some sort of way to also get 10 Gigabit Ethernet in the same system. I just think it's not possible with today's technology. Not yet. I'm probably going to have to give up and just go with a full ATX B550 / X570 build instead to get what I want, sadly.
X570D4I-2T by asrock rack is an option
I had no idea "ASRock Rack" existed. I'll look through these later today. Thank you.
its a small sub division just like how gigabyte and asus have one
Now that I'm done with dinner I can look into this. Wow, it has everything, even 10 Gigabit onboard and X570 chipset for Zen2 / Zen3. Looks like X570D4I-2T will do everything I want. ❤️ Nice find!
For anyone else looking at this thread and wanting to see what I was looking at, here it is: https://www.asrockrack.com/general/productdetail.asp?Model=X570D4I-2T#Specifications
