Hi guys
I'm just looking for a program that will check the temps of my cpu, as last night when i was live streaming my pc overheated, probably because i forgot to turn up the voltage on my fans, but id just like to make sure its a stable temp whilst streaming.
Whats the best program for it? (free)
Thanks again!
CPU Intel i7-6700k | Motherboard ASUS Maximus Hero VIII | GPU MSI GTX 970 | RAM 16 GB Corsair Vengeance 3000Mhz | Cooling Noctua NH-D15 | Storage 240GB Crucial M500; 2TB Seagate Barracuda | PSU EVGA 850w | Case Phatek Enthoo Pro M Acrylic
https://linustechtips.com/topic/121001-best-program-to-check-cpu-temps/
RealTemp GT
Edit: run some stress tests to see if the CPU just randomly overheated or if there's something wrong with your cooling.
realtemp doesn`t work with amd
use hwmonitor
Edited by s3ns3
hwmonitor or Coretemp or Realtemp(only intel)
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
Hi guys
Thanks again!
CoreTemp/Hwmonitor AMD
RealTemp Intel
Ok guys ill give HwMonitor a go :) thanks
Which temperature should i take as the actual measure?
There's two for the CPU
Most of the time, the ones under the CPU tend to be fairly accutate (within 2 or so Celsius of the actual).
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
Uh... Give me a minute. Gonna attatch an image I can look at.
Mine looks a little different the first set of temps, lists down from CPU, Mainboard, TMPIN2. And where it says the actual CPU name and temps, it has packages not core #0 :(
Can you get all of the stuff in a screenshot so I have a better idea?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Hopefully this helps
Oh. I have an older version, so it says something different. I would probably take the package and CPU (the one higher up) and average them out.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
I just downloaded Core Temp to compare, and it seems that the "package" temps, is the same as Core Temps readings :)
Remember, always take AMD temp sensors with a grain of salt. They are TERRIBLE.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
