I can't get my head around case fans.
24 minutes ago, LinusPCHelp415 said:What's your personal preference? And what's the most commonly used for noobs like myself.
Thanks for replying
Whichever you choose, it should be the same. Like @Eighjan said, it's just how the fan are being controlled.
Anyway, here are some tips to choose your fan:
- If you are using the fan to blow through a heat-sink or radiator, you need to use fan with high static pressure (usually rated in mmH2O). The higher the static pressure, the harder the fan can push the air into the radiator fins or heat-sink fins.
- If you are using the air to blow to open spaces, a high airflow fan will do the job well. They usually measure in CFM (Cubic Feet per minute) or CMH (Cubic Meter per hour). The higher the value, the more air it can push.
- There are some fans design for all in one (they can be used for both application, having decent amount of airflow and static pressure). These fan usually aim for those who doesn't want to see a case with mix up fans (and usually for aesthetic purpose).
- You may need to check out the noise level and fan speed as well. If you are building a silence system, go for a fan that runs on low RPM, as they generate less noise. If you want a better performance fan, get a higher RPM fan.
- RGB LED is optional. It just make your system looks 'cool' and has no other cooling effects.
- Interfaces. Some fans (i.e.: Thermaltake Pure Plus fans) uses proprietary interfaces that requires their own proprietary controller, while many fans do use standard fan header and RGB header. Be sure to check which RGB header your fan uses, as they use different voltage and will damage your system if plug in wrongly. RGB uses 12V and has a 3 channel R, G and B to control the light making them having 4 pins while aRGB uses 5V, Ground and Data to control individual RGB light making them having 3 pins. As for the fan cable, they usually comes with either 3 pin or 4 pin socket, both of them can be connect to the fan header as long as you align pin 1 correctly. Many fans do come with a socket that has a notch so it can fit the fan header latch.
- Bearing type. Bearing plays an important role in any fan, and they determine the fan characteristic, such as how fast the fan can run and the longevity of the fan. If you are looking for a good lifespan, hydraulic fan (or some may refer to as fluid dynamic fan) has good life span (usually in around 350k hours to 450k hours MTBF), while rifle bearing can run at higher speed. You can learn more about these bearings in the net.
- Size does matter. Depending on the type of fan your case support, generally, bigger fans are more silent while having higher performance. If you compare 120mm fan to 140mm fan, you'll realised that 140mm fan runs lower rpm yet having better CFM.
- Price. No point of having a fan with the best of the best if it makes you broke.
Hope this helps you a little.
Regards,
Chiyawa
