What is your oc specs? What games are you playing? and what temps are you experiencing?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1208990-possible-ram-problem/#findComment-13714586
3 minutes ago, Nickolass said:
Ive done 3d mark tests and my gpu and cpu got the scores they shouldve gotten.
Okay sure. That doesn't eliminate them as the issue though. Running fast on stress tests and game frame drops are two different scenarios.
Questions: Are GPU drivers up to date? Is this occurring in a specific game or multiple games and situations? Can you explain more what you mean by frame rate drops? What GPU are you running?
ask me about my homelab
https://linustechtips.com/topic/1208990-possible-ram-problem/#findComment-13714624
im using a 2060 super founder edition and yes, the drivers are up to date.  I dont play very many games, manily just sea of theives honestly. And while gaming ill just get frame stuuters and a tiny little screen freeze for a second.
https://linustechtips.com/topic/1208990-possible-ram-problem/#findComment-13714655
