It's not harmful, so you could go as low as the board allows as long as it's stable
Desktop benching:
2 minutes ago, Mahbub said:
Ok so like the normal shows 1.185v.. i offset .85 at first attempt.. is that ok or should i be less aggressive when reducing?
that's fine, I usually lower in 0.05v intervals.
Desktop benching:
Ok also i am seeing in cpu stress test that after undervolting the boost reaches 4.1 ghz instead of 4.3 advertised.. so now i feel to like overclock manually to 4.3 at 1.1v.. so i wanna ask in a manual overclock does the cou always run at the manually ovrclock speed during non load work.. or like turns down the clock just like it does if theres no oc applied
keep C-states enabled = clock drop during idle
Desktop benching:
Ok i made a mistake.. i increased the volt to default. 1.185 n running stress to find its same 4100 mhz.. i have another question. So like on 1.185v and 1.100v the cpu runs at the same 4100 mhz.. isint that harmful. Like the cou has to run the same mhz at a lower voltage... So like would that cause any harm? Amd i am planning to reduce it to 1v. And keep at 1v.. now if the cpu runs at 4100mhz at 1v stably i plan to keep it at that.. but will it be safe.. like forcing cpu to run at 4100mhz at much less volts.
it's safe. The only reason to not run lower voltage is because it will crash or drop performance otherwise
Desktop benching:
