Hi, all.
While I acknowledge that a Ryzen 5 running at high 60's/low 70's C, under load, is 'within spec'., I'm wondering if/how I can improve things?
CPU is currently under a be quiet! Pure Rock, on an MSI X470 Gaming Pro, in an Antec P280 with the three stock TwoCools as exhaust (2 roof, 1 rear) and two additional TriCools as intake.
Is the case inherently bad for cooling current levels of components? Are there better fans I could be using?
I've been considering a swap to a Meshify C as this gets rid of one impediment the P280 has - a drive cage where the air comes in.  If the Meshify C is generally a better case (certainly looks better behaved on the cable management front)
what (140mm) intake fans would be recommended for maximising airflow/cooling if the stock fans were on exhaust detail (1 rear/1 roof)?
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1207413-cooling-under-load-improvements/
First just take the side panel off and see if that improves temps. If so then it's an issue with airflow and the antec looks pretty closed off.
CPU: Intel Core i9-10900K 3.7 GHz 10-Core Processor
CPU Cooler: ASUS ROG RYUO III 360 ARGB White Edition All-in-one AIO Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z490-E GAMING ATX LGA1200 Motherboard
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3200 Memory Boosted to 4400MHz
Storage: 6 various HDDs and SSDs
Video Card: ASUS ROG Strix 3090
Case: Lian Li O11 Dynamic XL
Power Supply: Asus ROG Thor 1000w
Operating System: Microsoft Windows 11 Pro
Monitor: Samsung Odyssey G9 OLED 49"
Keyboard: Logitech G915
Mouse: Logitech G502 LIGHTSPEED
Headphones: Sennheiser RS 175
Mic: Blue Yeti
The case seems fairly restrictive at front. Like bad replica of R3/4. CPU cooler is midrange, so that could be better also. That being said, if we are talking about full load temps, you can't get much under 65C with just air cooling.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Reporting back...
Side panel off does mean that HWiNFO64 now shows:
... under load.
Funding is available for a Meshify C, but what additional fans (if any) would be recommended?
While I'm at it, I may as well re-TIM the cooler with MX-4.
WHY NOT...?!
Just get whatever fan fit the aesthetic you're going for. If you get too fancy with functionality they start to get expensive, that's why i have an open air case. Thermaltake core p3 I don't have to get fans.
There's already 2 fans inside both 120mm. you might be able to mount 3 in the front of the case but that may be a stretch. You can however fit 3 on the top. So you're looking at getting 3 or 4 or even 5 if you want to just replace both preinstalled fans. I would recommend Noctua just from watching LTT. But i've seen people go with corsair or even cooler masters.
Mic: Blue Yeti
Plunge taken - Meshify C (TTG) & two AER F 140's on their way...
WHY NOT...?!
