So i upgraded my pc
I5 8400
Gigabyte b360m gaming hd
Msi 1660 super
Samsung 860 evo m.2
Wd 1tb hdd
Cooler master mwe 550 80+ white
 After i install windows and update the display drivers my pc keeps restarting  on a loop, but if i direct open game it works fine. Can someone help me with this 🙏
https://linustechtips.com/topic/1207309-help-me-with-solution/
Reseat your GPU. Maybe you're running on integrated grahics atm. What did you upgrade and which parts were reused?
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1207309-help-me-with-solution/#findComment-13701508
-Moved to Troubleshooting-
https://linustechtips.com/topic/1207309-help-me-with-solution/#findComment-13701541
Ok ill try that
No its running on graphics card's graphics
Professor, motherboard, hdd and 1 ram stick is old. Gpu, power supply, ssd, 1 ram stick and cabinet is new
https://linustechtips.com/topic/1207309-help-me-with-solution/#findComment-13701665
2 minutes ago, Sammy Patel said:
Ok ill try that
Might be the ram sticks. Mixing kits isn’t recommended.
https://linustechtips.com/topic/1207309-help-me-with-solution/#findComment-13701669
