Monitor is 2k But 4K ingame??
Fictionvl
Go to solution Solved by mariushm,
6 minutes ago, Fictionvl said:
in game, I can set it to 1440p but the scaling is always on and if I go below 100% (4K) it becomes super blurry. and its for all games. not just a particular game
and I have set everything to default in the Radeon Software, GPU scaling is off, this only happened when I got my second monitor which is a BenQ EX2780Q
In the past I had some games do that scaling thing when I had that 125% text magnification in Display Properties ... don't know exactly the name in Windows 10 as I'm currently typing on a Windows 7 laptop
Basically setting something other than 100% for text scaling would make the game do that magnification crap.
Hello LTT,
I have a problem with my monitor, when I use it regularly it runs at 2K 144hz
but in games, for somereason running the game in windowed broderless runs them at 4K, and the scaling set to 50% to be at 2K, and its blurry.
I have an AMD 5700 XT GPU which i don't know if it has anything to do with this issue.
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
Go in control center / driver settings or whatever is called these days (adrenaline whatever) and check and see if there aren't some custom options configured for that game. Check if there's some super resolution option enabled or forced resolution or supersampling... basically anything outside the normal.
Is the game not allowing you to manually set the 1080p resolution, if not from menu from some configuration file?
did you check steam forums or origin or whoever owns the game for some bug fixes or known bugs / workarounds for this game?
You're 100% right, I had 125% on windows scalign cause everything was so small
