Its a good idea to change the thermal paste on a card this old and considering its on the older side, its good insurance to do so. Good ways to check is if the graphics card gets super hot in games/benchmarks etc. I bought a second hand RX 480 blower and the thermal paste was already dried out, changed it a couple days ago and runs great.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
If you're getting a decent deal for it, it's probably fine. Replacing the thermal paste is probably always a good idea with older gpus as @CommanderAlex mentioned. The card may be older now, but it's still able to handle modern stuff, if at lower settings. For longevity, it's probably going to be fine, IF it wasn't used for cryptocurrency mining or flashed to run way above manufacturer limits.
rubber dome apologist
It probably would be good to do so, my GTX 960(in use since 2015) was reaching over 80C a few weeks ago even with light use and after changing the thermal paste the temperatures don't go over 65C even in heavier use, and that because the fan only turns on after 60C.
I would say that the age itself isn't really a problem, but Kepler didn't exactly age well, if possible look for a RX470 as it should have a similar price to the 770 while being newer and faster.
