I do use Gigabyte GTX 1660 for last 2 weeks.
My room temperature is high.
On ideal my gpu has 50° degree temperature when gpu fan speed is 49%
Maximum it got 79° degree on 96% gpu usage (on rainbow six siege)
I'm really concern of my gpu fan and temperature.
I Know if the temperature gets more than 80°c might be a issue but on ideal temperature it's too high.
Is there any way to check if my gpu / gpu fans are fine or not !!!!
https://linustechtips.com/topic/1204226-gpu-fan-issue-curve/
What's the temp inside your room? Is it also 27C? What's your fan speed under load? I also believe the 1660 has a max temp of 95C.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1204226-gpu-fan-issue-curve/#findComment-13675921
If you are living in a place where things go dusty too much, then you might need to clean your pc once a week, to avoid dust bumping on your fan creating layers that will eventually slow down your fan or might just have it not working correctly.
that will cause the problem.
Consider cleaning your PC every week so you avoid replacing new fans.
I suggest you use SpeedFan to see if your fans are running in the correct speed.
Pancakes and Hell 🥞 , @Naul so i can notice ^^.
Demon girls are Cute!
Helltaker is a good game Click >> here << if you want to see.
https://linustechtips.com/topic/1204226-gpu-fan-issue-curve/#findComment-13675935
It's around 31 degree in my room .
Haven't check my max load gpu fan's speed !
https://linustechtips.com/topic/1204226-gpu-fan-issue-curve/#findComment-13675940
I use msi afterburner.
As far as ik it's running correctly !
https://linustechtips.com/topic/1204226-gpu-fan-issue-curve/#findComment-13675961
