Ryzen 5 3600 temperature
lipiosians
hey. I'm new here. I've been going through these forums and google search a lot whenever I encounter something that I need a little help with. I just now finally decided to sign up so I could ask my own questions and hopefully be able to answer some and be of help to others here.
I recently built a ryzen 5 rig (my first build) and I am worried about my temperature readings. I have found contradicting statements regarding acceptable temp readings. I've read some say idle should be between 30 and 40 Celsius while full load should be between 60-75. Others say up to low 90's at full load are still within normal range. with the stock wraith stealth, I got a peak of 95 degrees and an average of 85 after running prime 95 for 20 minutes. i recently bought a 6 heat pipe cooler and lowered the average to around 65 degrees after running prime 95 for 30 minutes but it still peaks at 85. should I be worried?
it should also be noted that the ambient temperature during the tests were between 30 and 35 degrees ( i know. that's how hot it is right now where I live. and that's at night!)
any feedback (warnings, reassurance, suggestions, etc) would be greatly appreciated.
I recently built a ryzen 5 rig (my first build) and I am worried about my temperature readings. I have found contradicting statements regarding acceptable temp readings. I've read some say idle should be between 30 and 40 Celsius while full load should be between 60-75. Others say up to low 90's at full load are still within normal range. with the stock wraith stealth, I got a peak of 95 degrees and an average of 85 after running prime 95 for 20 minutes. i recently bought a 6 heat pipe cooler and got lowered the average to around 65 degrees but it still peaks at 85. should I be worried?
Anything below 95C is safe, ideally you want it as low as possible for the highest possible boosting.
Quote me or @TwilightRavens if you want me to see your reply. I may go inactive for a long time from time to time because I forget how to socialize, but I will be back... eventually.
Main Gaming PC
AMD Ryzen 9 5950X || AsRock X570 Taichi || G.Skill TridentZ Neo DDR4 3600MHz 2 x 16GB C16 1.35v || AMD Wraith Prism || Phanteks Enthoo Pro E-ATX || Gigabyte RTX 3080 Ti Gaming OC || Samsung 970 Evo 250GB NVME SSD & Samsung 980 Pro 2TB NVME & Crucial 960GB SATA III SSD || EVGA Supernova 750W Platinum PQ || Windows 10 Pro 22H2 x64 || Gigabyte M27Q 27" 170Hz 1440P & Acer 21.5” 1080p 75hz IPS || Logitech G213 Prodigy || Logitech G502 Hero
Laptop
AMD Ryzen 5 4600H with RadeonGraphics || ASUS TUF A15 ||  DDR4 3200MHz 2 x 8GB C22 1.2v || ASUS GeForce GTX 1650 4G GDDR6 || 512GB NVME M.2 SSD  ||  Ubuntu 22.04.1 (Jammy Jellyfish)
Honestly, this seems fine to me. I mean PRIME95 is such an unfair test, it pushes your CPU like almost nothing else you would do in actual usage.
My advice, track the temps over a day or so of normal usage and reflect on that. Theres no point looking at a number that you will probably never really see if any real world use case.
PS the temps seems fine given your ambient temp imo.
My Folding Stats - Join the fight against COVID-19 with FOLDING! - If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
  • CPU
    Ryzen 9 5950X
  • Motherboard
    Gigabyte Aorus GA-AX370-GAMING 5
  • RAM
    32GB DDR4 3200
  • GPU
    Inno3D 4070 Ti
  • Case
    Cooler Master - MasterCase H500P
  • Storage
    Western Digital Black 250GB, Seagate BarraCuda 1TB x2
  • PSU
    EVGA Supernova 1000w
  • Display(s)
    Lenovo L29w-30 29 Inch UltraWide Full HD, BenQ - XL2430(portrait), Dell P2311Hb(portrait)
  • Cooling
    MasterLiquid Lite 240
Also modern AMD and Intel CPU’s will thermal throttle when hitting 95C and 100C respectively, so its pretty hard to damage your CPU via temps.
Main Gaming PC
Laptop
thanks for the quick response guys. that really put my mind at ease. 👍👍👍
