Budget (including currency): 1000 Dollars
Country: Sweden
Games, programs or workloads that it will be used for: AAA Games, now and hopefully in the future.
So, i have already got an monitor, mouse, keyboard and ethernet cable. I wan't to build an pc for 1k dollars and i wan't to get my parts on black friday or cyber monday.
I was thinking about these parts:
Amd ryzen 5 3600 or 3600x
(no idea what motherboard)
(used) rtx 2080
650w psu
(don't know if i need) Corsair hydro H55
16 gb ram
(some case)
1tb ssd
https://linustechtips.com/topic/1203467-what-parts/
Country: Sweden
(used) rtx 2080
650w psu
Corsair hydro H55
16 gb ram
(some case)
1gb ssd
You gonna overclok? Also a 1 gb ssd doesn't exist. A rtx 2080 is basically a rtx 2070 super for 200 more dollars. Lastly the most you can get out of a 1000 dollar pc is something like a 3600 5700xt build and that is still stretching the budget so there is no way you can put a rtx 2080 unless it's 400ish dollars.
Quote me for a reply, React if I was helpful, informative, or funny
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1203467-what-parts/#findComment-13669839
asrock b450 pro 4
msi b450 a-pro/gaming pus/tomahawk/mortar MAX
Corsair hydro H55
worse than most cheap air coolers
650w psu
550W are enough, make sure to get a good quality one. look for B+ and above from the PSU tier list in my signature
https://linustechtips.com/topic/1203467-what-parts/#findComment-13669860
Thanks for the help! But
6 hours ago, boggy77 said:
Thanks for the help! But does not ryzen 5 come with an cooler? And I have found a cheaper motherboard, MSI B450-A Pro Max. Do you know what's the difference?
https://linustechtips.com/topic/1203467-what-parts/#findComment-13670678
I'm not going to overclock. I have found old rtx 2080s for around 500 dollars and I think I would be able to find an 2070 super for around 400 dollars. Do you think an 5700xt is as good as an 2070 super or 2080?
https://linustechtips.com/topic/1203467-what-parts/#findComment-13670713
yes, it comes with a cooler. it's a bit noisy, but it works.
msi b450-a pro max is good as well, but it has just 1 m.2 slots.
make sure not to get the msi b450m-a pro max, which is trash.
both 2070s and 2080s are better than the 5700xt
https://linustechtips.com/topic/1203467-what-parts/#findComment-13670929
