Help choosing PSU
Go to solution Solved by Robchil,
Just now, Gamer Guy said:
So, these 4 are enough?
one is bronze, and the white is standard.
that's the diifference, more or less.. one cable for periferals more on the bronze one.
bronze are more efficiant, than the standard one.. but only by 5%  so it might have a bit longer lifetime ..
but i would go higher if i planned on overclocking in that system.
R3 3300X
MSI B450 Mortar MAX
MSI GTX 1660 Gaming X
I have these options to choose from:
Corsair CX Series CX450 450 Watt 80 Plus Bronze Certified ATX PSU (CP-9020120-UK) - 47 USD
Cooler Master MWE 550 Bronze - V2 Power Supply (MPE-5501-ACAAB-IN) - 55 USD
Cooler Master MWE 550 White 230V - V2 Power Supply (MPE-5501-ACABW-IN) - 44 USD
The reason why I mixed 450w and 550w PSUs is I'm a little bit worried with the "gray" list in the PSU tier list, as the cooler master bronze, white V2 are written in gray letters and the note says "units with various issues and concerns, see notes in the spreadsheet" but still in the recommended for mid range systems list. Should I worry about the issue notes? I really want a solid PSU because i might upgrade to a better CPU in the future and may overclock it + GPU and I do not want any voltage stabilization, ripple, etc etc electrical problems.
Also in general, which model is built better? Corsair CX (2017) or  Cooler Master MWE V2?
https://linustechtips.com/topic/1203448-help-choosing-psu/
1 minute ago, Robchil said:
it's harder to sell white PSU's so they are usually cheaper if they stocked up on them :D
if color doesn't matter get the white one. just check that it has:
Over Voltage Protection
Under Voltage Protection
Over Power Protection
Short Circuit Protection
Both looks same on the cooler master website. They both have the matte dark gray enclosures, not white?
https://linustechtips.com/topic/1203448-help-choosing-psu/#findComment-13669832
true.. so it's just a series name. they look the same tho, altho the white one has no bronze rating, only 80plus.
i compared on the coolmaster site.
usually you get what you pay for, but it's so small difrerences here it's hard to say :D
https://linustechtips.com/topic/1203448-help-choosing-psu/#findComment-13669852
So, these 4 are enough to look for?
https://linustechtips.com/topic/1203448-help-choosing-psu/#findComment-13669859
https://linustechtips.com/topic/1203448-help-choosing-psu/#findComment-13669881
How is the efficiency in any way related to the lifetime? Do you know what efficiency means?
https://linustechtips.com/topic/1203448-help-choosing-psu/#findComment-13669929
