USB stick in RAW format
Solved by TempestCatto,
Had this exact same thing happen to me, but it was with a Windows install usb stick. Go on a totally different computer and then try all the CMD stuff, or anything else you found. I had to use a machine different to the one that I made the install with, in order to recover it back to NTFS.
Featured Topics
eric_s ·
Posted in Power Supplies4 -
1
Silencix ·
Posted in Cases and Mods1 -
4
LambdaBird ·
Posted in General Discussion5 -
2
12
4
2
