  What case ? fan sizes are probably in the manual
Hi
hi
https://linustechtips.com/topic/1202254-fan-sizes/#findComment-13660122
then 90mm square frame fans should be the one it's designed for.
Desktop benching:
https://linustechtips.com/topic/1202254-fan-sizes/#findComment-13660130
Those are likely 80mm and 92mm fan sizes. :)
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/1202254-fan-sizes/#findComment-13660195
Yes, back then 120mm fans were a bit rare in consumer cases. 80mm and 92mm were the norm. I've got a 3900 RPM 92x34mm beast, probably one of the strongest fans I have lol. It'll take your fan header out if you hot plug it :D
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1202254-fan-sizes/#findComment-13660236
5 hours ago, Cloaked said:
I’ve run into a bit of a pickle with my search for fans.
Most of the 95mm fans I could find were from brands I’ve never even heard of before, and didn’t come with an outside casing for them. Would a 92mm fan work with 95mm fan mounting holes?
95mm is not right. 92mm is what you want.
https://linustechtips.com/topic/1202254-fan-sizes/#findComment-13661844
