Budget (including currency):
Country: USA
Games, programs or workloads that it will be used for: 2D and 3D Animation, Gaming(GTA to heavily modded Minecraft to Rainbow 6), Photo and Video Editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have a guess at a list but for sure I will need a new keyboard and a monitor, I currently have no parts of the build bought; didn't want to mess it up. I want to play at 1440 or higher. The faster the refresh rate the better. I'm looking to spend no more than 2500.00
Here is my guess at a list
https://linustechtips.com/topic/1201233-building-my-first-pc-please-help/
Country: USA
Hey @Rej900, welcome to the forums.
Kindly mention ur budget.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
When your internet adapters are more than your CPU :)
Not sure I understand that.
Can definitely shave some money if you wanted to,  like losing the soundcard as well.  And Windows, my god don't pay them.
That case... Are you more interested in form than function?
You're under your budget, but you could repurpose so much of that money into actual performance.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
He did.  $2500.
OnePlus Ecosystem:
3D Printing:
1 minute ago, Dedayog said:
He did.  $2500.
My bad....I didn't read down there.
SSD TIER LIST
CPU - Ryzen 7 3700X
18 minutes ago, Rej900 said:
Firstly, that is a weird build. 3600 in a $2500 budget. U can easily add in a 3700x and a 2080ti in that kind of budget.
22 minutes ago, Rej900 said:
At that point, just get something like this. (Good audio, integrated 10gig Ethernet, and inbuild wifi)
https://pcpartpicker.com/product/6W3mP6/asrock-x570-creator-atx-am4-motherboard-x570-creator
SSD TIER LIST
CPU - Ryzen 7 3700X
Originally I chose the AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor, I was also having issues finding a good match between the motherboard and the case. It kept having USBs that were going to be non functional.
Good Idea, but I dont see a 2080Ti that will fit in with my price range.
Tell me about it :) Not sure how else to install windows without paying them.
1 minute ago, gloop said:
"The ARCTIC Freezer 34 eSports DUO CPU Cooler may require a separately available mounting adapter to fit the ASRock X570 CREATOR ATX AM4 Motherboard." not sure about this warning also not sure if that will be enough memory. I could be wrong.
If you wanted to, you can keep the original Hyper 212. The arctic will perform better as it has 2 120mm fans, I'm really confused on what that warning message is.
Ok, yeah I was just worried about needing an adapter.
58 minutes ago, gloop said:
$500 motherboard?  Cut that to $200 and you can afford the 2080Ti.
500GB NVMe for $150?
I'm at a loss.  So much money spent on things that don't add performance.  Least you recommended the Windows key.
OnePlus Ecosystem:
3D Printing:
I went off the motherboard based on @VEXICUS's suggestion, and I went for the 970 Pro as OP had it in their original build. They listed 2d/3d animation, and Photo/video editing. The speeds will help with those workloads.
Think again ....
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($274.99 @ Amazon)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($89.90 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($189.99 @ Best Buy)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  ($149.99 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($132.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 2080 Ti 11 GB AORUS XTREME Video Card  ($1199.99 @ Newegg)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($99.98 @ Newegg)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Best Buy)
Wired Network Adapter: Asus XG-C100C PCIe x4 10 Gbit/s Network Adapter  ($99.99 @ B&H)
Total: $2337.81
Generated by PCPartPicker 2020-05-28 14:45 EDT-0400
$150 to spare. U can even upgrade ur CPU to r9 3900x. The Mobo that I have included has onboard wifi. So no need of a dedicated card.
Also, the GPU that I have added is one of the best 2080ti's out there (honestly it looks dope).
Windows keys can be had for $10-15 from sites like eBay, scdkeys, kinguin, etc.
Good luck & Enjoy.
SSD TIER LIST
CPU - Ryzen 7 3700X
I think I got it all. Thanks for all the help. Here is the newest list.
7.81 over is nothing. Again thanks!
