Processor Air Cooling
Go to solution Solved by WoodenMarker,
5 hours ago, Taintedmind said:
I've decided to go w/the Dark Rock 4, but I'm still curious if the Corsair LL120/140mm RGB fan will work on it, since the fan that's on there stock is 135mm; so it appears it might alter where the holes will be grabbed to the metal sync.
The 135mm fan uses 120mm mounting holes. They're also centered at the fan instead of at the outer edges so you would need to bend the wires to fit normal 120mm or 140mm mounting holes.
The NH-D15 Chromax heatsink itself is 160mm. The height is 165mm only with the fans in their standard mounting position. The cooler can be used with the center fan completely lowered into the heatsink and with the front fan at the rear for pull or removed for a total height of 160mm.
If you want to use LL's on the cooler, you might as well get a different cooler to begin with. What ram are you using?
I have a few questions, if anyone is able to help.
I'm looking to possibly purchase an i9-9900k after the new computer parts come out later this year to put in my current rig to give to my g/f over my i7-8700k w/an EVGA RTX 3070 FTW2.  I'm goin to build my own PC w/the new computer parts and hand this one to her.  I was looking at two coolers to see which one would be better at either Auto config and/or Sync All Cores on the i9.
I'm looking at:
Be Quiet! Dark Rock 4 (159.4mm w/135mm fan)
Noctua NH-U12S chromax.Black (158mm w/120mm fan)
I was looking at the Noctua NH-D15 chromax.Black, but there'll be clearance issues w/her Cougar Panzer-S case by 5mm.  Case CPU Cooler max is 160mm and the NH-D15 is 165mm w/2 140mm fans.  It would be tight, but there might be a possibility of just slidin the fans a 5mm lower for clearance; if this's an options, please let me know, along w/the other info.
I was wondering which one would have better cooling (I would assume the Be Quiet due to one more heat pipe w/a larger fan) and if either would be able to use the Corsair LL120/140mm RGB fans.  I have both sets of fans, so it wouldn't be an issue of putting it on - I'm asking if they're compatible.
Anyone useful info on this subject is appreciated; thanks.
Primary
OS:        Windows 10 - Professional (64-bit)
CPU:      i9-10900k 3.7-5.3GHz (10th gen)
GPU:      EVGA RTX 3080ti FTW3 Ultra Gaming 12gb
MB:         ASUS RoG Maximus XIII Hero (ATX)
RAM:      64gb (4x16) DDR4-3200MHz G.Skill TridentZ Silver/Black (CL16)
HD:         1x 8TB Corsair MP400 NVMe PCIe 3.0 (SSD)
               2x 16TB Seagate Exos 7200rpm (HDD)
E-HD:     12TB WD
PSU:       EVGA 1000w G2, 80+ Gold (modular)
UPS:       900w CyberPower
Display:   ASUS 27” 1440p/270Hz IPS 0.5ms (XG27AQM)
                Aorus 27" 1440p/165Hz IPS 1ms (FI27Q-P) iGPU
KeyB:      EVGA Z15 (wired)
Mouse:    Logitech G-502 Hero (400/600/800/1000)
Headset: JBL Quantum ONE Gaming Headset
Case:      Cooler Master MasterCase H500P Mesh (ATX)
Other:     XB-1 Wireless Controller Adapter w/Controller
              NPET H01 Gaming Mouse Bungee Cord Holder w/4 USB Ports
Gaming Computer Specs.pdf
https://linustechtips.com/topic/1199806-processor-air-cooling/
The old school method is count the pipes.  The i12 has five and the dark rock has six.  This leads me to suspect that the dark rock has a higher total TDP.
https://linustechtips.com/topic/1199806-processor-air-cooling/#findComment-13642337
Primary
E-HD:     12TB WD
https://linustechtips.com/topic/1199806-processor-air-cooling/#findComment-13642402
https://linustechtips.com/topic/1199806-processor-air-cooling/#findComment-13643320
G.Skill TridentZ RGB 3200MHz 32gb (4x8).  The entire build is in my Signature, if you require any more info.  The clearance of the case is the issue - I wanted to get the Noctua NH-D15 chromax.Black as I've stated prior, but this case has limiting clearance issues w/being more flexible w/non-Liquid Cooling.  I only want Air Cooling in this rig.
Primary
E-HD:     12TB WD
https://linustechtips.com/topic/1199806-processor-air-cooling/#findComment-13649469
Le Grand Macho RT
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1199806-processor-air-cooling/#findComment-13649830
You could get a Ninja 5 instead: https://pcpartpicker.com/product/dZ3H99/scythe-ninja-5-430-cfm-cpu-cooler-scnj-5000
https://linustechtips.com/topic/1199806-processor-air-cooling/#findComment-13649943
