today while i was playing the division 2 on my 3440x1440 monitor with a 5700xt and R5 3600 my pc turned off 2 times i noticed that one of the times my gpu was at 80c then the second time i put the game at low everything it still turned off, any ideas of what it could, also noticed my gpu was at 1200mv at 2070mhz. is that normal?
https://linustechtips.com/topic/1198641-help/
Just now, GoodEnough said:
if you have an unstable overclock for either, your cpu or gpu, your computer will simply turn off.
set your gpu to 2035 mhz and see if that fixes your problem, the rx 5700 xt should be able to handle that with no stability issues
those are the out of the box settings
https://linustechtips.com/topic/1198641-help/#findComment-13633712
3 minutes ago, Hendricks3 said:
i kid you not when i opened the radeon experience thing it said that at 1200mv that was its target. i literally had to undervolt it
rx 5700 xt's usually run extremely hot, so most people undervolt them, but i really wouldnt have the frequency any higher than 2000 mhz for stability
https://linustechtips.com/topic/1198641-help/#findComment-13633735
also someone asked me what psu am i running im running an evga 600b 600w psu if it matters
https://linustechtips.com/topic/1198641-help/#findComment-13633737
1 minute ago, Hendricks3 said:
weird thing is after a 100mv it stopped turning off
might of been a heat issue, only time i encountered a heat issue is when i was doing some extremely unsafe stuff with my processor, testing how high i could oc it, apparently stock cooling couldnt handle it too well and the processor reached 110c
https://linustechtips.com/topic/1198641-help/#findComment-13633750
i thought that too so i took msi afterburner and set the gpu fans at 100% as i run my cpu and case fans at 100% since i dont care much about acoustics and it shut off too
https://linustechtips.com/topic/1198641-help/#findComment-13633754
then it has to be a frequency/oc issue, thats all i can think of
also i thought it was my outlet as we been having weird electric which fried my brother's mobo and his girl power brick but when i undervolted and it stopped i thought it might've been the psu as someone asked me
https://linustechtips.com/topic/1198641-help/#findComment-13633760
I doubt the GPU is overheating. I only have experience with one AMD GPU and that was an R9 390, an MSI model. It would run hot in some games and get noisy. From what I understand is that it's normal and ok for the 390 to get up to 80 or 85 degrees Celsius. I heard AMD cards tend to run hot and loud. So I doubt that has changed with the new cards.
It's why I went back to Nvidia. Nvidia cards usually run quiet, cool and better.
https://linustechtips.com/topic/1198641-help/#findComment-13633974
2 hours ago, GoodEnough said:
600w is plenty for an rx 5700 xt
yes the wattage is enough but that is really low and poor quality unit. i would get a better one before something else happens.
no they dont run any hotter than other gpus. people just usually buy a gpu with low end cooler, and that is why they run hot. and 2070mhz is normal. since radeon works like that.
The rx 5700 XT boosts itself as high as it can without exceeding thermal and voltage limitations. and i doupt that the card is overheating since the gpu would have slowed itself down. seems like psu issue. try with better quality unit.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1198641-help/#findComment-13633984
never had issues with my 1080 until today
https://linustechtips.com/topic/1198641-help/#findComment-13634187
yeah most aftermarket cards have fixed the heating issue, but im talking about the original amd radeon rx 5700 xt.
https://linustechtips.com/topic/1198641-help/#findComment-13634738
